Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-07-2011, 12:42 PM
ECONZO ECONZO is offline
Garage is empty, add now
ECONZO is starting off with a positive reputation.
Need help with vin on early panel econoline!
I just bought a early panel econoline and the guy said it was a 1962. I am thinking it may be later. I thought it had a 144 motor but now thinking its a 170. Any help with decoding this vin would be great. Here is the vin I found stamped in the back corner.
E14TH496572
THANKS!
  #2 (permalink)
Old 12-07-2011, 01:26 PM
tjc transport's Avatar
tjc transport tjc transport is offline
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
welcome to FTE.
it seems like the VIN is incomplete
the vin decoder i use can not decipher it.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
  #3 (permalink)
Old 12-07-2011, 01:38 PM
Glad to be here! I am pretty sure that is the vin I took off yesterday but I may be wrong. I will have to check it out tonight. I have had a lot of trouble just trying to figure out the year with this vin, so it make since.
  #4 (permalink)
Old 12-07-2011, 01:41 PM
if i remember correctly the vin plate is on the driver side door under the striker
__________________
Tom
  #5 (permalink)
Old 12-07-2011, 02:10 PM
I will check it out tonight
  #6 (permalink)
Old 12-07-2011, 08:25 PM
Just checked the vin again in the back corner of the van and the vin plate on the door. Both have the same vin
E14TH496572
W.B. 090
Color T
Model E143
Body 489
Trans A
Axel 01
3600 85 3600 65
Any help with this would be great
  #7 (permalink)
Old 12-08-2011, 07:45 AM
something is still wrong. there should be a number at the very start of the vin before the E.
i have 5 different vin decoders and none of then recognize that number.
__________________
Tom
  #8 (permalink)
Old 12-09-2011, 10:58 PM
EmilBarnabas EmilBarnabas is offline
EmilBarnabas is starting off with a positive reputation.
January 1964 would be my guess. The VIN looks fine, but I'm not the VIN expert.
There is a little triangular shelf/support between the dashboard and the steering column. The two bolts holding it to the steering column: horizontal in 1961-1963 (heads point towards seat), vertical in 1964 (heads point towards roof).
  #9 (permalink)
Old 12-14-2011, 04:50 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by ECONZO View Post
E14TH496572 / W.B. 090 / Color T / Model E143 / Body 489 / Trans A / Axle 01 / GVW 3600 / Cert. net HP 85 / RPM 3600 / DSO 65
Welcome to FTE
E14 = Econoline Van.
T = 170 1V I-6.
H = Lorain OH Assembly Plant.
496572 = 1964, assembled January 1964.
90" Wheelbase.
T = Navajo Beige.
E143 = Econoline Van, 3,600 lbs. GVWR
489: 4 = Light Beige Crush Vinyl & Light Beige Stitch Pattern Vinyl / 89 = Econoline Van.
A = Ford model HEF-AH 3 Speed Light Duty Manual Transmission.
01 = Ford WCC-A Rear Axle / 3.50-1 / 2,300 lb. Rear Axle Capacity.
3,600 lbs. Gross Vehicle Weight Rating.
85 net HP @ 3,600 RPM
65 = Oklahoma City OK Ford District Sales Office, where the original selling dealer ordered the Econoline from.
VIN & Warranty Plate decode info taken from the 1964/72 Ford Truck Parts Catalog.
Quote:
Originally Posted by tjc transport
it seems like the VIN is incomplete. the VIN decoder i use cannot decipher it.
Something is still wrong. There should be a number at the very start of the VIN before the E.
Wrong? Uh...you are referring to a 17 digit VIN, this ain't it.
This 11 digit VIN is 100% correct. The 11 digit VIN is essentially the same for all series of 1961/80 Trucks, Econolines and 1966/80 Bronco's.
17 digit VIN introduced in 1981. The first digit is a number, decodes to the country of origin. 1981/96 examples: 1 = USA / 2 = Canada / 3 = Mexico.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #10 (permalink)
Old 12-14-2011, 04:52 PM
actually, Bill, i was referring to the older car VIN that starts with a number to designate the year.
all 3 of my 11 digit VIN decoders called that an incomplete VIN because it did not have the year number.
__________________
Tom
  #11 (permalink)
Old 09-23-2012, 07:10 AM
fathr04 fathr04 is offline
fathr04 is starting off with a positive reputation.
HELP! i have a Old ice cream truck, Ford, vin to decode
i have purchased a White Massey panel van, Ford drive train, i need help to decode a 11 digit vin,
P10JH424362
I want to restore her, and get her back on the road selling ice cream in style, please help
  #12 (permalink)
Old 09-23-2012, 09:59 PM
P10 = P100 model truck
J = gasoline-powered, 223 cui, 6 cyl, 1 barrel carburetor, 114 HP @ 3600 RPM
H = Assembly plant is Lorain, Ohio
424362 = serial number, assembled in June 1963, 1963 model year.
Do you have the rest of the codes on the data plate?
I'm looking at the different forums here at ford-trucks.com, and I think your P100 belongs on the Large Truck discussion board.
Let me know when the ice cream is ready.
Emil
** Note to the next person who needs a VIN decoded - start a new thread.
Quote:
P10JH424362
Tags
11, 1962, 1964, 65, decoder, decoding, differential, digit, econoline, find, ford, hefah, panel, rear, truck, van, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
