96 350 duelly rear adjusters ?? to tighten ? - Ford Truck Enthusiasts Forums
Old 12-07-2011, 11:12 AM
mike bell mike bell is offline
mike bell is starting off with a positive reputation.
UP or Down......everthing is new every answer you want is out there and chiltons talks about 17 different trucks in the same paragraph.......the brakes seem to be unadjusting....I want to be sure before I reverse them....I even read where 1 side goes 1 way and the other side is the reverse DOES ANYONE KNOW FOR SURE WHICH WAY TO TIGHTEN ???? thxs mike
Old 12-07-2011, 11:16 AM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
I guess you're talking about rear brakes?
The starwheel goes both ways, but one way is a lot easier and if you spin it that way the shoes should move out. If they go the other way, then you got them backwards.
Old 12-07-2011, 12:22 PM
Phy's Avatar
Phy Phy is offline
Phy has a good reputation on FTE.Phy has a good reputation on FTE.
Assuming the adjuster was installed correctly, you move the end of the lever you're holding up to tighten. The side of the adjusting star facing the access hole has to go down, so your hand has to go up...
Old 12-07-2011, 01:21 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
On self-adjusting brakes, there is a pawl on the opposite side of the access hole that must press the star wheel DOWN to adjust it tighter, so that means on the opposite side, where you are attacking it with your brake tool, it must go UP.
Old 12-07-2011, 03:08 PM
THERE IS THE ANSWER !!!UP TO TIGHTEN !
THANK-YOU now I can deduce if its reversed or what.....mike in omaha
Old 12-07-2011, 03:26 PM
andym's Avatar
Quote:
I can absolutely guarantee that the direction the starwheel spins is not universal on every vehicle.
Old 12-11-2011, 02:58 PM
I have ripped the drums off....as the stars go
DOWN to tighten THE BRAKES CAME UNADJUSTED (solid but to the floor ) after pushing snow for 4 hours.....THE PARTS STORE guy said for sure there is no left right drivers side........now they are tight again.....but every diagram says the starwheel threads go forward.......to make this thing go up to tighten with the tool, I put the starwheel threads to the right or rear....do I have my BASS AKWARDS OR WHAT ???
Old 12-11-2011, 03:51 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
If you swap the self adjusters left to right they will self un-adjust. One side has left hand threads. Pull on the self adjusting cable and release, watch the adjuster lever, it should turn the starwheel in the right direction to tighten the brakes.
Old 12-11-2011, 04:02 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
This should help ya out, (disregard the part circled in the diagram, it was for another purpose)
And yes there most certainly is a left and right sided self adjuster, one of them (don't recall which at the moment) has left handed threads.
Some kids got no business working at auto parts stores, the shear volume of miss information given out these days is just ridiculous.\
Edit:
I should have mentioned the opposite side would be mirror image of this side, do not install the same on both sides. Side in diagram is the left side (drivers side). Example, the self adjuster cable and its adjuster lever goes with the rear shoe both left and right sides.
And might be worth mentioning you'd only need one side wrong to adversely effect pedal travel. Say for example the parts guy sold you two "left side" adjuster screw assemblies rather then a right and a left set.
One side would work to back the shoes off over time as you used the brakes causing excessive pedal travel, the other would adjust the shoes properly. It only take one side and not necessarily both, seams the adjusters are stamped with a "R and "L"? If not you can work it out using the picture make sure you have them on the right side.
Old 12-11-2011, 06:07 PM
Phy's Avatar
Phy Phy is offline
On mine, the auto adjusting lever pushes the star wheel up to tighten. This means the inner side, by the adjusting hole in the backing plate must go down to tighten...
Old 12-11-2011, 08:36 PM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe Bootlegger's Deluxe is offline
Bootlegger's Deluxe is starting off with a positive reputation.
i've had the same issue with poor pedal travel on my F350 ... and i've heard of others as well ... i've adjusted them many times before ...
Old 12-11-2011, 08:40 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
that is what i seem to recall too.been a while though.
down to tighten the drivers side and up to tighten the pass side.
it's not exactly all that hard to figure out though.she only wants to spin one direction.if it spins easy the wrong way on ya,then guess what? you need to tear it down and replace your adjusters anyway lol.if you don't then your brakes wont remain adjusted,and they wont self adjust.
Old 12-18-2011, 12:16 PM
thanks for your help....I pulled the cable to see what way it should go to tighten....then made sure the stars were correct QUESTION FOR YOU I am reinstalling my salter (like yours ) IS THERE ANY POSITIVE OR NEGATIVE to the hydrolic lines......1 goes out quick connect to the auger moter then out of there to the spinner then a line back to the other q connect how do you tell or does it matter ??
1950 F5 rear brake dragging animaldawg 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 10-20-2014 09:45 PM
which way to adjust rear drum brakes? 2002sport 1987 - 1996 F150 & Larger F-Series Trucks 6 09-07-2014 07:10 PM
1951 F1 loose steering box mike01082 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 10-29-2010 11:00 AM
reverse lights upgrade mtondreo 1997-2006 Expedition & Navigator 8 12-23-2009 06:26 AM
08 super duty stick shift sloppy! boots6868 1999 to 2016 Super Duty 6 09-01-2008 06:02 PM
Tags
1993, 2001, 99, adjusters, adjustment, brakes, bronco, cable, cd4e, diagram, escape, f250, ford, ranger, rear, schematic, spin, star, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
