Fuel gauge an Miles to empty questions - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-19-2014, 02:36 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
Quote:
Originally Posted by lllateralus View Post
Bottom line, if you ran out of fuel with the gauge showing 1/8th of a tank, you have a mechanical problem.
I vote pull the tank and check the foot on the pickup, and clean the contacts on the fuel level swing arm. They hang loose down in the bottom of the gasser tanks right? Maybe it got shifted.
Old 04-20-2014, 09:20 AM
96fordsix 96fordsix is offline
96fordsix is starting off with a positive reputation.
Greetings, reading all these posts brings up a question, How much of the fuel is usable?
Old 04-20-2014, 10:34 AM
pcavender pcavender is offline
pcavender is starting off with a positive reputation.
'14 SD CC 250 gasser
Glad to see this topic. I recently traded a 1/2 ton Lariat Limited with the 6.2 for my SD 250 6.2. I was accustom to the 35 gallon tank and failed to verify tank size on the SD. Dealer can't accurately tell me tank size. All gauges and information related to MTE, gallons consumed and the fact that I have filled 27.5 gallons twice with gauge reading 1/8+ fuel remaining. I am assuming I have the 35 gallon tank. Any help would be appreciated.
Old 04-20-2014, 12:43 PM
minke minke is offline
minke is starting off with a positive reputation.
Quote:
That is exactly the right question. I don't know if there is a low area to collect any sludge or gunk. I wonder how low the inlet goes.
I've refueled with MTE in single digits and never put more than 31.5 gallons in the 35 gallon tank. ('11 xl w/ 6.2)
Old 04-20-2014, 03:06 PM
Shovelheadrob's Avatar
Shovelheadrob Shovelheadrob is online now
Shovelheadrob is starting off with a positive reputation.
Ok then, has anyone actually run to empty? I mean until the truck stalls. I'm curious as my 2012 Transit van has a built in to the PCM misfire which kicks in at around 8/9 mte. It will also cut the motor before it runs out of diesel completely.
Do our trucks have anything like this?
If run out of fuel, do they start right up after putting some more fuel in the tank?
Lie-O-Meter Wingit929 1999 to 2016 Super Duty 11 05-19-2016 01:16 PM
2005 Navigator fuel gauge inaccurate, but... bbells2009 1997-2006 Expedition & Navigator 3 06-22-2015 09:37 AM
Fuel sending unit 1979 f150 DTW79 1973 - 1979 F-100 & Larger F-Series Trucks 8 08-28-2014 11:23 PM
Replaced fuel sender - still not working cchvacman 6.0L Power Stroke Diesel 8 08-10-2014 03:30 PM
Overhead Computer (Miles to Empty Question) lacofdfireman 6.0L Power Stroke Diesel 19 01-10-2005 10:17 PM
Tags
2010, 2011, empty, escape, f150, ford, gallons, gas, gauge, incorrect, king, miles, ranch, showing, size, tank, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
