Driveline troubles when in reverse
Over the last few weeks I have noticed some issues with my truck, when in reverse. Usually, when leaving work, I back out of my spot and notice after about 20-30 feet a slight thump followed by a sensation similar to applying the brakes.
Yesterday I replaced the starter in the truck and had the batteries disconnected for several hours. This morning when backing away from the curb, that braking sensation presented itself again, but much worse. I was only able to back up about 5 feet before the truck came to a halt with very little accelerator. Applying more accelerator gave me a sensation almost like that of power braking (one side of the truck torquing upwards slightly).
Truck drives fine in all forward gears, but now it seems as though reverse may be completely out of the question for me.
When I arrived at work, I plugged in AE and think I saw a P1828 under the DTCs, but I made the stupid mistake of clearing them before I confirmed that. Once I got home I ran DTCs again, but did not find another P1828.
Any thoughts on what I need to start looking at in this thing? My big fear is the transmission is on the way out.
2003 F250, 7.3L with 188k on the odo, 4R100, auto transfer and hubs. No tunes.
I had the exact same issues over time with my dually. The end result was the differential ring and pinion bad, as well as the spider gears missing chunks. Remove the rear diff cover and inspect for damage of any and all gears. My pinion looked like it had a severe case of cavities on the back side of the gears is the best i could explain, therefor not showing an issue while driving forward. Once I took it apart I also noticed a piece of the spider gears missing. Mine started showing symptoms while backing up at a angle and then to the point where it almost didnt want to back up.. Best of luck to you.
Definitely not the ebrakes holding things up. I've been able to confirm them disengaging when I release the pedal. But I suppose there is always a chance that they are reengaging when I am backing up.
Thanks for all the help guys. Not exactly what I really needed right now. Wife had a hard enough time buying the idea of buying injectors. A new trans is going to make her even happier!
If you have limited slip don't forget friction modifier or use a gear lube that already has it. I used Valvoline Syn Power that had friction modifier in it. Didn't need to add any additional friction modifier.
And Bob is the winner. Lesson learned for me tonight: never discount something as checking out until you do a THOROUGH inspection.
As it turns out, the right rear emergency brake lever was hanging up. I pulled the caliper and top hat where I found the shoes had been extended out to almost constant contact with the interior of the rotor. Dialed them all the way down and buttoned everything back up. I won't be using the emergency brake again until I get the cable situation figured out. Seems to not want to release tension when the pedal is popped.
On a positive note, the rear diff looks great. And now it has new fluid in it. Probably could have saved myself some time tonight had I just jacked up the rear end and spun the tire by hand FIRST. But, at least I serviced my rear diff.
Thanks again guys.
Thanks again guys.
Chris Ellis
03-07-2016 09:05 AM
78 Ranger
08-15-2006 06:12 PM
