HELP - Clunking in 4 wheel drive in 2007 FX4 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 12-06-2011, 02:54 PM
geostone geostone is offline
geostone is starting off with a positive reputation.
There is a clunking sound and feel from the front end of my 2007 Ranger FX4 when in 4 wheel drive. This happens sometimes but not always on engaging or disengaging 4 wheel drive, as well as sporadically while driving along. I took it back to Ford on warranty with this problem last year, and after a few attempts I had them admit that something was wrong and they finally diagnosed that it was the front drive shaft that was binding where it leaves the transfer case, this was replaced. I have now put maybe 50km (max) on in 4 wheel drive and the problem is back, I don't think the problem was ever fixed. Any suggestions would be helpful.
Old 12-06-2011, 08:41 PM
Dutter's Avatar
Dutter Dutter is offline
Dutter is starting off with a positive reputation.
what do you do to make it clunk, sometimes you brake shoes will move back and forth in the caliper iv had that happen
Old 12-06-2011, 10:03 PM
It sometimes but not always clunks when going in or out of 4by, also when just driving along straight, but only in four wheel drive, it can clunk about every 10 to 30 seconds. The faster I'm going to more impact there is.
Old 12-06-2011, 11:47 PM
Dutter's Avatar
hmmm sound like there not fully unlocking, or a hub got broke. But to break a hub you would of had to been doing some hard wheeling. So what id do is put the truck up on jack stands when you take it out of 4x4, And start spining the tires by hand and try to find the sound. What im thinking is that, its a hub or the T cast not fully unlocking. But that just my guess
Old 12-08-2011, 01:43 PM
reddog99 reddog99 is offline
reddog99 is starting off with a positive reputation.
Dutter, these models don't have locking hubs.
My vote goes to a bad CV joint on one of the half-shafts....
Old 12-08-2011, 05:29 PM
Dutter's Avatar
Ok then maybe the T case isnt unlocking, But i agree it very well could be the CV
Old 12-08-2011, 05:55 PM
Yeah from what I can feel it is probably the Tcase, I've had bad cvs in another truck before and it doesnt feel like this, that was more on turning and even in two wheel drive, this is strictly in 4wheel and often when engaging or disengaging. Sometimes after I click out of 4 wheel there is a few second delay and then the final clunk comes and I can feel it has actually popped out.
Old 12-08-2011, 08:40 PM
The clunking going in and out of 4-Low is normal, but it should be nearly undetectable when shifting into 4-High. Clunking while driving is no-good either. Have you checked the transfer case oil level? (grasping at straws here).
Old 12-08-2011, 11:21 PM
Dutter's Avatar
Yeah check the oil, it should take ATF, now iv herd that if you tap the little electric motor on the T case with a hammer itll get that motor to turn the Tcase into 4 and 4low easier. And if that dosnt do it, try taking it off and cleaning out the motor with electronic cleaner spay. And thats assuming that you have a push button 4x4 like me. So try those ideas and get back to me
Old 12-08-2011, 11:25 PM
grandmas77f150's Avatar
grandmas77f150 grandmas77f150 is offline
grandmas77f150 is gaining momentum as a positive member of FTE.
Wait, do you still have the warranty? If you do, take it to them
Old 12-09-2011, 01:36 PM
I assume that it's off warranty now, but you had it in and worked on under warranty for this issue last year, and it was never actually repaired. Take it back in and see if you can get them to complete the repair under warranty.
Old 06-08-2012, 07:25 PM
tjbushey tjbushey is offline
tjbushey is starting off with a positive reputation.
Hey there wondering if you found out what it is ? i have the Exact same problem with my truck and being trying to figure out, ive replaced both cvs as well cause i thought that was the problem but i still have it... ive checked all Fluids as well and electrical connections.
Old 06-08-2012, 09:11 PM
Bruker's Avatar
Bruker Bruker is offline
Bruker has a very good reputation on FTE.Bruker has a very good reputation on FTE.Bruker has a very good reputation on FTE.
^I don't know if you've checked but a dry slip-yoke will cause a "clunk".
Old 09-27-2012, 09:47 AM
gridleak gridleak is offline
gridleak is starting off with a positive reputation.
Hi all,
I have the same issues with my 2006 Ranger. But mine feels and sounds like it comes from the behind me. No clunking when going into and out of 4 wheel drive. Only when driving.
Sounds like something is gonna snap each time it does it. Checked everything external with no luck. Looks like I need to start taking things apart and looking.
Old 10-01-2012, 07:35 AM
cpb2.3 cpb2.3 is offline
cpb2.3 is starting off with a positive reputation.
sounds to me like the chain in the transfer case is stretched and slipping
2007 chassis clunk noise, help! khadma Explorer, Sport Trac, Mountaineer & Aviator 2 11-06-2016 02:33 PM
2007 FX4 clunking sound 07F150Lariat5.4 2004 - 2008 F150 2 04-08-2016 10:33 PM
4x4 problems Cook9917 Clutch, Transmission, Differential, Axle & Transfer Case 7 02-12-2016 12:56 PM
2014 F150 FX4 Feel "clunk" in steering wheel while driving straight. wgm114 2009 - 2014 F150 15 09-30-2015 01:34 PM
07' F250 Front Wheel Clunk BlackLabel 1999 to 2016 Super Duty 4 08-07-2015 06:00 PM
Tags
2004, 4wd, 4wheel, 4x4, case, clunk, clunking, drive, driving, f150, ford, ranger, straight, transfer, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
