HELP - Clunking in 4 wheel drive in 2007 FX4
Old 10-01-2012, 08:39 AM
BigBlackSD08's Avatar
BigBlackSD08
BigBlackSD08 is offline
Mine had much the same sound it took ford a few time over a period of a year to diagnose that it was a gear in the transfer case on ice it would clunk and the power would transfer to the rear wheels.
Hope this helps.
Old 10-01-2012, 06:38 PM
reddog99's Avatar
reddog99
reddog99 is offline
It would seem more likely for the sound to be coming from the transfer case than the CV joints. On the newer models, the driveshafts turn all the time, so the CV joints are turning whether or not you're in 4WD.
By the way, if you hear this sound while running in 4WD on hard surfaces, then that is the cause of the noise. You are NOT supposed to do that. It's bad for all the parrts involved. You're only allowed to do that if your vehicle has a center differential, which the Ranger does not have.
Old 11-26-2013, 09:00 PM
rangerdude06's Avatar
rangerdude06
rangerdude06 is offline
My 06 ranger has the same issue. Clunking every 10-15 secs in 4h and every min or so in 4lo. Only when I'm on the throttle. No noise when coasting. I put the truck on 4 jack stands and ran in 4h and 4lo. No clunking. Checked the front drive shaft and looks ok. Thought it could be the shift motor so I replaced it and the clunking is still there. Thinking of rebuilding the t-case.
Jamie Comeau
11-24-2018 08:31 AM
zgraham
12-16-2013 02:07 AM
rlatak
1997 - 2003 F150
02-01-2008 09:17 AM
iyak
12-02-2006 02:30 PM
The Chipster
Bronco II
01-19-2004 08:23 PM
Quick Reply: HELP - Clunking in 4 wheel drive in 2007 FX4
