6.7 Glow Plug dropped ( pic added ) - Page 2 - Ford Truck Enthusiasts Forums
Old 12-07-2011, 03:27 PM
BCM's Avatar
BCM BCM is offline
BCM is gaining momentum as a positive member of FTE.BCM is gaining momentum as a positive member of FTE.
50,000 miles? Did you get an extended warranty?
Old 12-07-2011, 04:22 PM
EpicCowlick's Avatar
EpicCowlick EpicCowlick is offline
EpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant future
04xcur - is this on a C&C or regular pickup?
Old 12-07-2011, 04:35 PM
Painted Horse's Avatar
Painted Horse Painted Horse is offline
Painted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud of
Quote:
What does an extended warranty have to do with this problem. The engine is covered for 100,000 so he is still covered.
Old 12-07-2011, 04:38 PM
BCM's Avatar
BCM BCM is offline
Quote:
I see. Did not realize the warranty went 100,000 miles. Thank you for the clarification.
Old 12-07-2011, 04:39 PM
Hdslider's Avatar
Hdslider Hdslider is offline
Hdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputation
I haven't heard of a pickup doing that, on CC yes. Only heard of a few pickups where bolt came loose and blew injector out.
Old 12-07-2011, 05:49 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Quote:
Is there some explanation for that? Are the engines different in the cab/chassis than the pickups? I know the tuning is slightly different, but I'm not sure how that would explain injector or glow plug blowout.
Old 12-07-2011, 06:30 PM
Front Runner's Avatar
Front Runner Front Runner is offline
Front Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputation
Quote:
He stated he has a regular pickup.
I'm interested in seeing how this turns out. It should be covered under warranty.
Old 12-07-2011, 08:32 PM
Thanks, I missed that. This is the first time I've heard of it on a regular pickup. Someone earlier this year had the same issue but it was on a cab & chassis. I'm glad Ford is retrieving the entire engine for analysis.
Old 12-08-2011, 12:15 AM
Monorail_Red Monorail_Red is offline
Monorail_Red is starting off with a positive reputation.
Subscribing, hoping the best for OP.
Old 12-13-2011, 10:27 PM
04xcur 04xcur is offline
04xcur is starting off with a positive reputation.
Latest news : Cracked valve !
This week, i stopped at the dealer and to my surprise, the mecanic told me that now they are sure it was a cracked valve... He thinks that it should be covered under warranty ( 99% sure ! )
here is the pictures:
Old 12-14-2011, 01:14 AM
Did a number on the top of that piston didn't it?
Old 12-14-2011, 01:57 AM
bookem15 bookem15 is offline
bookem15 is starting off with a positive reputation.
WOW it sure did.... I can not wait to see how this turns out. Good luck I sure hope Ford covers this.
  #28
Old 12-14-2011, 09:04 AM
Hdslider's Avatar
That's just plain sick.hope they get you going as quick as possible.
  #29
Old 12-14-2011, 10:06 AM
Those are amazing photos. I'm curious as to what the final repair will be. Clearly they have to replace the piston but what about the cylinder walls, the rod and the crank? Does the entire head have to be replaced? Any mechanics in the audience?
  #30
Old 12-14-2011, 10:27 AM
bpounds's Avatar
2 bit Californian
I don't understand how that is a cracked valve. All the valves in that cylinder look intact in the head, and even look properly positioned in their seats, and no damage to the valve bottoms. The witness marks on the piston and head look consistent with the damage that would be done by a small metal object in the cylinder, like a glow plug tip. Maybe I'm missing something?
Check engine light!!!! Stroking13 6.7L Power Stroke Diesel 4 09-14-2016 11:20 AM
a couple of glow plug replacement questions rcorell 1999 - 2003 7.3L Power Stroke Diesel 5 03-05-2016 01:37 PM
Issues jtorrez22 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 20 07-11-2015 11:48 AM
Possibly broken glow plug in IDI 7.3 Turbo Lexrocker Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 06-06-2015 07:51 PM
Ongoing Problems-Please Help! DAI532 1999 - 2003 7.3L Power Stroke Diesel 25 09-01-2009 11:29 AM
Tags
64, 67, 73, blew, damage, diesel, dropping, f250, ford, glow, operation, oxford, plug, plugs, topper, valves, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
