Oil change on an oil burner?
my dad has a 98 f150 4.6 with 160,000 on it the oil hasnt been changed for some time i keep telling my dad we should change it but he thinks because its burn about a quart of oil every thousand miles that is shouldnt need changed....
is there any truth to this?
I have owned 4.6L engines in lincolns that burned 1 qt every 300 miles and they still need the oil changed. There is NO truth to this whatsoever. The 4.6/5.4/6.8 can use oil thru the valve stem seals. This in no way effects the engines durability or classifies them as "junk". It is a simple problem and a simple fix (if the engine is out).
A 4.6L can still make it to 300k no problem if maintained correctly. I have one with 182k and it runs like new with no oil burning in 3k mile intervals.
EcoboostKev
17
11-26-2014 07:52 PM
