Plastic clips on rocker arms, assembly only? - Ford Truck Enthusiasts Forums
Old 12-06-2011, 02:59 AM
FSeybert FSeybert is offline
FSeybert is starting off with a positive reputation.
Are these plastic clips there to hold the rocker arm during assembly only? Do they serve any purpose once the engine is in service?
Thanks,
Fred
Old 12-06-2011, 10:18 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
I've heard reference to these clips, but my '03 didn't have any plastic clips when I did headgaskets. Did that change from a metal clip to plastic in the later years?
Old 12-06-2011, 09:28 PM
They are indeed plastic now, not sure when they changed. Here is a link that shows one:
Ford Rocker Arm Clip, Plastic
I think they are for assembly purposes only, but want to make sure. Anyone who knows please reply.
Thanks,
Fred
Old 12-07-2011, 12:43 AM
Yep, those clips were metal in my '03. Sure don't like all the plastic pieces...
Old 12-07-2011, 09:27 PM
Does anyone have an answer? I have a broken clip, I don't think it's a concern, but want someone with a little more knowledge to shed a little light here, please.
Thanks,
Fred
Old 12-07-2011, 09:32 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
Yes, unfortunately later model year engines use the plastic rocker arm pivots, and NO they are NOT used for assembly purposes only. If you have a broken one, REPLACE IT before you lose your rocker arm.
Old 12-07-2011, 09:57 PM
Thanks for the reply. To replace it requires removal of the carrier? Will this also disturb the head gasket and require replacement, or am I missing something?
Thanks.
Old 12-07-2011, 10:06 PM
m-chan68's Avatar
Rocker arms can be removed without removing the cylinder bolts. But to do so, requires use of this tool:
https://rotunda.spx.com/en-US/Pages/...x?itemID=18452
This tool is used to to compress the valve springs by clamping down on the valve bridges, with the fuel injector removed.
If you do manage to obtain this tool, be very careful not to drop the rocker arm pivot ball during rocker arm removal. Removal by this method ensures that cylinder head to block clamping is not disturbed.
Old 12-07-2011, 10:10 PM
Thank you very much for the info. It is greatly appreciated.
Old 12-07-2011, 10:19 PM
If you don't want to buy the tool, there are several people that have done headstuds successfully one at a time. You could probably get by with removing the head bolt and reinstalling a new one (since they are TTY, you shouldn't re-use them). Or, better, upgrade to studs right now.
Old 12-10-2011, 10:27 PM
I always hate searching for information, finding the thread that has just what I am looking for and then there is no finish, no outcome so to say. With that said, I replaced the broken rocker retainer clip today, with no issues at all, it slipped right in. No really, it did. Popped right over the pedestal and clipped on. Thanks for the heads up about this M-Chan.
replacing rocker arm on a 6.4 question speakerfritz 6.4L Power Stroke Diesel 6 12-10-2016 07:15 PM
replacing rocker arm on 6.4 question speakerfritz 6.4L Power Stroke Diesel 3 12-06-2016 08:35 PM
Question about Rocker Arms RideDiesel88 6.0L Power Stroke Diesel 7 05-04-2014 02:40 PM
Plastic clip in rocker arm? blownchevy 6.0L Power Stroke Diesel 2 04-30-2013 01:29 PM
Plastic clips on rocker arms grudgeracer 6.0L Power Stroke Diesel 1 03-24-2009 08:18 PM
Tags
08, 2004, 2008, 60, aftermarket, arm, arms, broken, diesel, f250, ford, international, remove, rocker, rockerarm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
