302 cylinder head question - Ford Truck Enthusiasts Forums
Old 12-05-2011, 11:08 PM
caleb_ford caleb_ford is offline
caleb_ford is starting off with a positive reputation.
Hey guys needing some opinions on cylinder heads , I just bought a 93 short bed with a 302 in it, the truck either has a blown head gasket or a cracked head , so the heads are getting replaced the question is should I just put stock F150 heads on it, but I also thought about putting GT40 or GT40P heads on the engine , would the GT heads be a gain?
Old 12-06-2011, 10:34 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
GT40's flow about 20% better than the stock E7TEs and GTP heads about 30% better.
Old 12-06-2011, 02:36 PM
Conanski, can a GT40 or GTP heads be put on a stock 302 F150 engine with no mods to the fuel system or the intake or computer ?
Old 12-06-2011, 03:35 PM
jimbbski jimbbski is offline
jimbbski is starting off with a positive reputation.
You should not need to make any changes other then the question of the exhaust and plug angle on the GT40P heads. New plug wires may be needed if you are using anything other then stock cast iron manifolds.
Old 12-06-2011, 11:31 PM
Conanski's Avatar
Quote:
Yes no problem at all.
Old 12-07-2011, 08:08 AM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
Before you bolt em on, make sure the leak is from the heads or gasket. Could be a cracked block too.
302 Gt-40 Heads Horsepower miashley150 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 01-31-2013 06:44 PM
302 gt40's vs 351 gt40's - valve springs specs spidermonkey Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 05-14-2008 11:50 PM
Performance heads Gt40, E7TE???? gov2mod 1978 - 1996 Big Bronco 1 05-28-2005 01:08 PM
head swap question for 77 302 gt40p littlefullsizeranger Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 9 09-10-2004 01:35 PM
Anyone use gt40p heads on 351w? Questions... daytoncobra Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 02-20-2001 03:27 PM
Tags
150, 1978, 302, 50l, 90, cylinder, f150, ford, gt40, gt40p, gtp, head, heads, intake, interchange
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
