Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
  #1 (permalink)
Old 12-05-2011, 08:19 PM
Jordan84 Jordan84 is offline
Garage is empty, add now
Jordan84 is starting off with a positive reputation.
temp sending unit
i am having trouble finding the temp sending unit on my wifes 2003 explorer with the 4.6 can anyone help me
  #2 (permalink)
Old 12-05-2011, 10:02 PM
shorod's Avatar
shorod shorod is offline
2010 Lincoln MKT
My Garage
shorod has a good reputation on FTE.shorod has a good reputation on FTE.
On the 2003 with the V8 the "temp sending unit" is the "Cylinder Head Temperature Sensor". With the hood open, if you were to stand on the driver's side fender and look at the engine, the connector for it is located just above the upper left of the valve cover. The sensor has a pigtail on it. It will have two wires to it, a Yellow/Light Blue wire (reference voltage) and a Gray/Red wire (signal return).
It sounds like you're fishing for an issue. Care to share some details on the symptoms?
-Rod
  #3 (permalink)
Old 12-05-2011, 10:26 PM
Rod thank you for replying so quickly. the temp guage in the cluster does not read at all so when you try to start the vehicle in morning it starts pretty normal but if the vehicle is warm it wont hardly start. A local mechanic told me that since the temp sending unit is not working that the computer automatically defaults to -40 and gives the engine to muck fuel but when it starts it has another temp sensor because it runs fine and the onboard diagnostic shows that the temp is ok. What is your thought
  #4 (permalink)
Old 12-06-2011, 06:55 AM
shorod's Avatar
2010 Lincoln MKT
My Garage
I scrubbed the factory service manual for the V8 because it surprised me that the PCM would use the Cylinder Head Temp (CHT) sensor as the sole coolant sensor. There's no other temp sensor showing for the engine control or the gauge. I'm used to Ford using an Engine Coolant Temperature (ECT) sensor for the PCM and a Coolant Temperature Sending (CTS) unit for the gauge. Apparently that's not the case here.
The wiring diagram for the instrument cluster shows the coolant temperature gauge as getting signal from the PCM, and the PCM getting signal from the CHT sensor so there is no other sensor that the PCM uses when the engine is cold. It would seem that maybe you have an issue with the wiring harness that allows the PCM to get a good signal from the CHT sensor when cold, but as the engine bay heats up, something expands and goes open circuit for the CHT sensor. It could be the sensor, it could be in the wiring, and I suppose it could be something else.
You wouldn't happen to have a scan tool with a datastream mode or some other OBD-II data logger (Maybe a smart phone with the free Torque application and OBD-II dongle) would you? It would be interesting to watch the coolant temperature parameter as you drive and as you attempt to start the engine when warm.
-Rod
  #5 (permalink)
Old 12-06-2011, 09:04 AM
I dont have a scanner but i might be able to get ahold of one if i find anything i will let you know. thank you
Tags
1999, 2008, 42, 54, 97, engine, escape, f150, food, ford, problem, sending, temp, temperature, thermostat, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
