Transmission Mount?
Transmission Mount?
I might be buying a 89 F350 Diesel as a donor truck to my F6. I will be using the motor, crossmember, mounts, ect. The only problem is it has the auto tranny in it and I will be using a zf5 in my project. So my question is the tranny crossmember/mount the same for the auto tranny as the zf5? Thanks for the help
the mounts seem to be the same , and the crossmember should work but if you are putting the combo in that old 49 thats in your pictures then you will have to do some fabrication on that crossmember or make a custom one from scratch !
will be a good project and be sweet when done so good luck !
maschronic
05-06-2007 11:59 AM
1978fordf250
06-19-2004 04:16 AM
