F-150 vs. F-150 HD
F-150 vs. F-150 HD
Alright, I have a question about the F-150 HD payload package now available on the 157" WB screw. From what I've read so far, I know one can get an extra 500 lbs. payload (along with 8200 lbs GVWR) 7-bolt wheels, a 3.73 LS differential and a few other items. The question is how did they get the extra 500 lbs payload on the truck? I found no indication that Ford has changed its frame and the 2012 source book doesn't say anything about adding leaf springs.
If all Ford did was beef up the rear end a bit more, the why can't one just add a set of air bags and LT tires at a later date and save the price difference?Everything else seems to be the same including the 9.75 rear end.
Does anyone have any inside information on this?
Thanks in advance!
Thanks in advance!
No, the rear end is not the same, I believe.
Here is the list of upgrades with the HD payload package as far as I know:
- high capacity wheels
- LT tires
- HD shocks
- upgraded rear axle: 9.75" gear set (instead of 8.80")
- upgraded springs
- upgraded radiator and aux. transmission oil cooler
- stronger frame on all but screw (0.150 instead of 0.110 rail thickness). Screw has 0.150 rail thickness regardless of HD payload package already.
Also, it is an extra 500lbs of GVWR, not payload, from the max tow package. It's a full 1,000lbs extra GVW from the regular (none max tow / none HD payload) F-150.
If you really want to haul in the 2,000lbs weight range, I would recommend to get the HD payload package, because then no lawyer can argue that you were over the limits should you ever get involved in a nasty accident.
- LT tires
- HD shocks
- upgraded springs
How can Ford officially (and in all documentation) claim an upgraded gear set then for the HD payload package? Tim, is that information listed somewhere? I have the 2012 source book, but it's not clear to me which truck gets what gear set from that document.
My '88 had an 8.8 Ford rear end. I've seen many many 2004-2008 F-150's with the same size rear axle and many with the larger axle.
My 2011 EB has a larger rear axle housing than my '88 did and every EB truck that I've seen has the same size axle housing.
I very well could be jumping to conclusions in assuming that I have a 9.75 just because it looks bigger. It in fact may not be as I can't prove in any reading that I've done that a 9.75" is standard fare. Perhaps I should digress until someone more informed chimes in.
same rear end, they already made it stronger when the ecoboost was busting gears while in the testing phase. The only difference that I see is the 7 lugs, big deal. you can go with some airbags do the same thing and have adjustability. As far as I know the axle is not different, you would have to ask the guys at the Sterling axle plant
One good thing still is that one would be covered in case of an accident as long as you were not over the rating of even the HD payload truck.
But yes, in that case it would kind of suck what Ford is doing here .... $1,700 is one heck of an expense for 7-lug wheels.
You get the LT tires, upgraded shocks, upgraded springs?
That's above and beyond of what's included in the max tow package, right?
And I guess the rear axle IS different. I searched axle on partsguyed.com. There are different parts for the HD payload package. One example:
- axle shafts, f150, 9.75" axle, right, base payload pkg.
vs. - axle shafts, f150, 9.75" axle, right, heavy duty payload pkg.
But it looks like there are a few improvements for that price - so the rims are not quite the only thing.
$47 extra????
