EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
F150 EcoBoost Engine belts
Old 02-28-2012, 02:11 AM
dalejunior's Avatar
dalejunior
dalejunior is offline
First Post - bear with me !!!
Relatively new F150 EcoBoost fell victim to a suspected cat sleeping in engine compartment. Dont know the cats condition but the engine dropped both belts -- please don't laugh. Belts appear to be OK and I have access to the area from below (removed some of the shrouds). I can't tell how to relax the belts paths in order to reinstall - What appears to be the tensioner on the serpintine is not like any I have dealt with in the past. Info on any special tools or technique would be invaluable. Post back if I can provide more details. Thanks in advance - Dale
Old 02-28-2012, 09:43 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,220 Likes on 803 Posts
Welcome to FTE!
I popped the hood on my truck looking for a serpentine belt diagram and nothing. In the owners packet there is a very thin pamphlet that has the diagram on it. The idler pully is about center engine under what appears to be the a/c compressor or alternator. By the looks of the diagram, there is only one belt.
Let us know how it goes.
Old 02-28-2012, 10:53 AM
dalejunior's Avatar
dalejunior
More info on ecoboost belt problem
Tim - Thanks for reply,
My ecoboost has 2 belts the A/C goes toward passenger side - it is narrower and quite short with no obvious tensioning method - maybe the compressor is adjustable. Everything else is on the serpentine - it has what appears to be the tensioner (no shoulder on it) in the center above-right of the drive pulley - no obvious method for releasing the tension such as a 3/8 or 1/2 square drive hole - it's not on a pivot arm, so not easy to figure out how it releases. My 2011 owners book shows a routing diagram on page 415 - not showing the 2 belts clearly but otherwise OK. The crank pulley has 2 tracks on it - narrow one aft for the A/C - anyway, no problem with routing - only how to relax tension. If I knew that I could have it back together pronto. Sure appreciate your input. Dale
Old 02-28-2012, 10:59 AM
tseekins's Avatar
tseekins
tseekins is offline
Dale, this is great info and thank you sir. Sorry I couldn't help. I'm going to move this thread to the 2009+ F-150 forum and see if we can get more exposure.
halfbolt
12-09-2015 04:22 PM
dalejunior
2009 - 2014 F150
01-07-2013 10:15 PM
Motus_Nick
1983 - 2012 Ranger & B-Series
12-04-2007 07:34 PM
Aero4E
Aerostar
17
05-15-2003 08:00 PM
cadiecast
Aerostar
08-27-2002 12:39 PM
Quick Reply: F150 EcoBoost Engine belts
