tuners
My tuner is an Edge Race Evolution. After the DPF fell off and the programmer added I went from 10.5 to 14.8 mpg. If I had 14 mpg from the factory I would have left it alone. I strain at the thought of anyone getting 18 from a F350. An F250 2wd with 3.55 gears... yes, possibly. Bottom line is that the 6.4 is a thirsty beast.
so you gained 4.3 mpg yourself, why would you strain at the thought of an F350 doing the same, would a tuner and the right exhaust not help in that, and driving your vehicle the right way, I had a 06 kingranch and i added the bullydog and went from 16.5 to 21 on interstate, all i did was run the tuner on extreme, Tried it on the 09 F250 and it made the mpg worse.
I like it, I'm currently running the Automind tuner from Banks with the Six-Gun on the stock setting. For mileage, I've averaged 10-11 when it was only city driving, 13-15 when it was mixed and 18-20 when it's hwy driving only, literally station to station.
I've got the intake system and the dual exhaust. Both are very clean installs and look very well done. I have the 4in exhaust system as that's what they had at the time. They now have a 4in and 5in system available.
Thanks, I need to take a look at the options .Banks has a delete program ? or is this an additional program ?I just put the 6 gun on 3 wks ago and am more than pleased with the power but would like to be proactive about keepin her cool and running long .I don't really expect much more than the 12-14 mpg around town i'm getting now but when I tow a hauler [6,000 lbs] on vaca I'm hoping to see 16-18 mpg .have yet to vacation with it.do you have a 3.73 rear end? what mpg do you see on the hwy?
If you already have a Six-Gun or Automind you could use the DPF-R+ to turn off the regen/egr functionality and get even better results from your Six-Gun or Automind. If you don't have either one then you could use the supplied economy tune to receive good mileage results.
Highway mileage is typically better in most cases, except when towing. Towing always results in poor mileage. I wouldn't expect to get the 16-18mpg your expecting even towing that light. You'll probably be more in line with what your currently getting around town now with that load. As you start to go up in weight and size it will go even lower. Senix is towing at almost the max for an F250, I believe he sees around 7-9mpg. Mind you, this is with the DPF still in place, he could probably do better with the DPF removed, but still not in the 16-18 range. When your towing large loads, you typically want to be as close to stock power ratings as possible to prevent over heating and/or damaging your engine. So he runs his Six-Gun on the stock setting in most cases. If he were to do the DPF removal, he would still probably run it at the stock setting just because it's safer. The engine would most likely perform allot better with the simple fact that the DPF is removed so he doesn't have that restriction in place.
Both his and my truck have 3.73 gears in them.
No, they don't have a delete. The DPF-R+ is a separate tuner from a separate manufacturer altogether. It will allow you to turn off the regen/egr functions and install a 70hp economy tune.
tuners
Really appreciate the info :Smotrs,Senix thanks .Now I've got this compulsion to do something about the DPF and follow with adressing the EGR ,I followed the link for DPF+R and read about the regen sometimes putting fuel in the motor oil when the cycle has been cut short etc. That sounds like a time bomb ,spoke with a guy who removed the DPF and says he can put it back on if he needs to, but the EGR cooler is two units and blocking them off seems like stuffing a turd under the rug . he did not say whether he did anything with them ,so how does that work ? the aftermarket EGR coolers from B.P.D. in AZ. look like a good fix and I like the concept of keeping emissions and eng. temps down and not removing the coolers.
True, the regen function can introduce fuel into the oil, dilution, when the engine is turned off in the middle of a regen cycle. However, you can get the same type of dilution simply going on several short trips that don't warm up the engine enough.
To counter the dilution regarding regen, if you know your vehicle is in regen, you should put the vehicle in park and let it idle long enough for the EGT's to come down to a normal idle temp. This will give it plenty of time to burn off that excess fuel that was injected on the exhaust stroke. Regen will probably start again next time your on the road, but hopefully your on your way somewhere where it can completely finish.
To counter the dilution regarding short trips. Don't use the truck for short trips.
