Signals I would think to look at the flasher unit. Dim lamps I would pull a lamp and see what wattage your using. If I recall right you can get 2 different wattage lamps. be warned though if you don't know that the housing that the lamps anchor into can get very brittle and break from the heat of higher wattage/temp lamps
