printed circuit board on instument cluster - Ford Truck Enthusiasts Forums
Old 12-04-2011, 10:25 PM
Black Jack G Black Jack G is offline
Black Jack G is starting off with a positive reputation.
I am trying to replace a printed circuit board on a 1976 F150's instrument cluster. The one I took off has the instrument voltage regulator attached to it. Do you know how to remove it so it can be reused on the new circuit?
Old 12-04-2011, 10:30 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
The regulator is held on to the instrument cluster by one small hex screw. With it loose, gently pull off the section of the printed circuit that attaches to the regulator. It attaches to the printed circuit just like a 9-volt battery.
Old 12-10-2011, 12:13 PM
printed circuit
Duh!! I should have waited till I got the new circuit board before I posted a rookie question! Thanks alot for the reply.
Here's another one: I have it all together now, replaced bulbs and sockets, but the ammeter gauge still is not working. Is there a way to test the gauge itself? Do they go bad? All the others are original and work fine. Is it a wiring issue and if so how should I proceed?
Old 12-10-2011, 12:21 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
The factory ammeter is notorious for not working even when they were new! It was so bad that Ford had to issue a service bulletin on the subject.
It's not a wiring or mechanical issue, it's just a bad design.
The ammeter moves very, very little even when its working properly.
BTW welcome to FTE, a lot of good knowledgeable people here.
Old 12-10-2011, 12:30 PM
ammeter
Mike, Thanks alot for your reply. I would not have quessed that. I'll just check the battery to be sure the charging system is working.
I am really glad I found this website. You guys are awesome.
HELP: Dashboard Gauges Not Working mpope 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-06-2017 03:08 PM
Factory Tach dnkensinger 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 08-31-2015 08:17 PM
78 f250 printed circuit board 78ranger250 1973 - 1979 F-100 & Larger F-Series Trucks 10 08-09-2012 06:49 PM
circuit board colors roy123 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-05-2012 06:32 PM
C Series gauge cluster adharvey2 Large Truck 12 01-13-2011 06:01 PM
Tags
1976, 78, 79, board, circuit, circuitboard, cluster, f150, f250, ford, gauge, instrument, printed, removing, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
