Low tire pressure warning - Ford Truck Enthusiasts Forums
Old 12-04-2011, 05:38 PM
nut1605's Avatar
nut1605 nut1605 is offline
nut1605 is starting off with a positive reputation.
I rotated my tires a few weeks ago and forgot to reset the TPMS so it gave me the low tire warning. Reset it, everything was fine for a little while. Then the low tire pressure warning popped back up. I checked the tire pressure, and it was low, so I pumped all 4 up to 68 and the warning won't go away. Do I have to reset the TPMS again? Or does the system just take a while to detect the new pressure?
Old 12-04-2011, 06:04 PM
CascadeF250's Avatar
CascadeF250 CascadeF250 is online now
CascadeF250 is gaining momentum as a positive member of FTE.
Quote:
I had to drive my truck about 5 miles for the message clear in the information screen. I have never had a problem after rotating my tires. I keep 60 pounds in the rear and 65 in the front when not towing. I have 18 inch tires.
Old 12-04-2011, 06:25 PM
Painted Horse's Avatar
Painted Horse Painted Horse is offline
Painted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud of
Rather than mess with it. I just run the tires up to Max prssure (80psi) and run around the block and chase an errand or two, Then lower them to what ever pressure I want to run at.
If you are setting them close to the trigger point for the TPMS ( I think 62 psi) remember to set the pressure when the tires are the coldest.
Old 12-04-2011, 09:43 PM
nut1605's Avatar
I have put probably 60 to 70 miles on it since I pumped up the tires and the message is still there. They were at 60 psi, I pumped them all up to 68 after the truck sat all day, but the message still shows up. Driving me nuts!
Old 12-04-2011, 10:29 PM
Inflate them to the MAX pressure to reset them. 68psi isn't high enough.
Old 12-04-2011, 11:17 PM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
I went through this the other day after a tire rotation for the 18 inch Conti's.
Alert is 62 and 68 doesn't cut it as Painted Horse said.
I didn't take mine to max but that's the best route so you spend less time messing with the crazy things.
low tire warning not working meborder 1997-2006 Expedition & Navigator 2 06-24-2016 12:28 PM
TPMS warning light - did not reset nodima 1999 to 2016 Super Duty 13 11-12-2015 09:29 AM
TPMS Warning Light Won't Go Away Boomer23059 6.7L Power Stroke Diesel 6 09-13-2013 02:35 PM
TPMS is driving me nuts!!!! SuperDutyScaler 1968-2013 Full Size Vans 15 01-11-2013 08:27 PM
Low Tire Pressure Warning Rick Cargo 1999 to 2016 Super Duty 3 09-08-2010 07:10 PM
Tags
2009, 2011, escape, f150, f350, ford, hybrid, low, pressure, psi, reset, tire, transit, turn, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
