Towing Lights hookup
You might try running a cable from the flat 4 trailer connector on the tow vehicle to the flat 4 on the BII. That should supply the lights to the BII. You might need an electronic flasher on the tow vehicle. If you don't have the flat 4 trailer connector on either vehicle you can simply do it by installing the plug-in type "T" connector for the BII and the tow vehicle @ ~$25 each.
I just remembered that at one time I used the U-Haul "tap-a-lights" and connected them through from the tow vehicle... Pretty inexpensive, you can use them in the tow and in the BII. Simple and easy. You may still want to use the electronic flasher on the tow still.
first today
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
09-30-2009 02:54 PM
68-F250-4x4
23
01-21-2008 11:36 PM
bigric
13
08-12-2003 04:52 PM
