2003 Ranger 4.0 stalling at stops/low idle - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 12-04-2011, 09:59 AM
c.hawk71 c.hawk71 is offline
c.hawk71 is starting off with a positive reputation.
My 2003 ranger xlt 4.0 has a stalling problem. The engine light came on in aug and I had it coded at AutoZ and there was a code for the oxy sensor, changed that and didn't help so i took it back. In oct I had it coded and it said the air int temp sensor which i was informed was part of the mas airflow sensor, changed that the beginning of nov, got the computer to reset and it still didn't fix it. Took that part back and had it coded again a few days later and several codes came up AutoZ code 1732 and the the OEM number to cross for them were: P2195 , P0300 , P0316 , P0174 , P0171 , P2197 . Reset the comp yesterday and as soon as the light came on had them code it again and it came up AutoZ code 1732 OEM # to cross P2195. CAN SOMEONE PLEASE HELP??? If not I guess my next step will be to take it to the dealers to get diagnosed and pray its something that I can fix myself for not a lot of $.
Old 12-04-2011, 02:00 PM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Quote:
Welcome to FTE.
Boy you've been having a tail chasing go round with this puppy, so lets see if we can use the posted code definitions to unravel your mystery.
Basically they're saying you likely have a large vacuum leak. On your model 4.0L, the PCV valve rubber elbow dryrotting & causing a bad vacuum leak is a good suspect for your list. Maybe the PCV valve too, if it's time for it to be changed, as if its sticking open, that'll cause an uncalculated for & unmetered intake side vacuum leak/airflow intake that the MAF sensor isn't monitoring, so the air fuel mixture would go so lean the computer couldn't compensate for it, so idle would be off, or if it were bad enough the engine could stall, or you might have ping problems on a pull & you have codes saying both cyl bank O2 sensos are stuck lean & not switching, P2195 & P2197, P0171, P0174.
You also have a random misfire code P0300 & misfire on start up during the first 1000 rpm, P0316 & these may be caused by the vacuum leak, or you may have another problem thats being masked by the lean condition.
SO, begin to look for an intake side vacuum leak that would affect both cylinder banks & I'd suggest beginning with a check of that PCV hose & valve. If no joy, progress to other rubber vacuum hoses, especially those that connect to the engine intake manafold, or run close to anything hot, or that moves.
If no joy, rig a propane sniffer, using an unlit propane torch, length of rubber hose attached, whos loose end is fitted with a sports needle used to inflate foot or basket ***** & use it as a probe to run along the intake manafold gasket line with the engine at idle. If you have a leak & the engine gets a whiff, its idle speed will increase.
Let us know what you find.
Old 09-13-2014, 10:17 AM
sunny.richter sunny.richter is offline
sunny.richter is starting off with a positive reputation.
I had the same issue with mine. Took it to a mechanic, the while shop couldent figure it out. I gave it to my dad. He took it to NM. He called me a week later to come pick it up. He just beat out the catalytic converter and its been running fine since. Hope that helps
Old 09-13-2014, 10:31 AM
hodge5's Avatar
hodge5 hodge5 is offline
hodge5 is gaining momentum as a positive member of FTE.hodge5 is gaining momentum as a positive member of FTE.
"If no joy, rig a propane sniffer, using an unlit propane torch, length of rubber hose attached, whos loose end is fitted with a sports needle used to inflate foot or basket ***** & use it as a probe to run along the intake manafold gasket line with the engine at idle. If you have a leak & the engine gets a whiff, its idle speed will increase."
That's fantastic! This is why I join forums- to find nuggets of wisdom/experience/tricks of the trade like this!
Old 09-13-2014, 10:43 AM
David7.3's Avatar
David7.3 David7.3 is offline
Where is the beer?
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
When was the last time you changed the fuel filter? That will cause a lean condition, as well as your fuel pressure regulator, the first sign of a blocked cat is while driving at a steady speed you get a surge or stumble, thats the egr letting to much exhaust into the intake causing a missfire, the blocked cat increases the amount of exhaust going into the egr, so if you dont have EGR codes I wouldn't worry about the cat. Does sound like a vacuum leak and those PVC hoses that get soft and break are more for the triton v-8 than your 4.0, dont forget about a throttle body service, Ive seen that simple thing get over looked again and again. And that's for a stall when coming to a stop but it wont set lean o2 codes, thats fuel or vacuum. Stop spending money and start diagnosing her.
P2195, P0059, P1000, P0330, U0121, P0351... so many codes!! Please help!!! AGrayson84 1997-2006 Expedition & Navigator 4 11-01-2016 10:35 AM
‪P0171, P0174‬, ‪P2195, P2197‬ codes after cleaning throttle body HelenT Modular V8 (4.6L, 5.4L) 0 10-09-2016 01:35 AM
Code P0153 P0133 2000 Ranger just report it as stolen? rogerranger2122 Ranger & B-Series 23 08-08-2016 07:24 PM
03 Explorer P2196 & P0405 Code Question wiwillis1980 Explorer, Sport Trac, Mountaineer & Aviator 1 06-22-2014 06:22 PM
code P2195 driving me nuts. john5240 Escape & Escape Hybrid 3 05-07-2013 12:26 PM
Tags
2003, 2007, 40, bad, ford, idle, idling, liter, low, ranger, rangerstops, rough, stall, stalling, stalls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
