1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
04 f350 with 5.4. auto transmission problems
Old 12-03-2011, 09:57 PM
bicounty's Avatar
bicounty
bicounty is offline
I just bought truck. Only has 63000 miles. After driving for a few days I started feeling a vibration. At first I thought I was running over rough spots in pavement like the warning marks on the shoulder. It starting doing it more frequent so I began taking notice of when it was doing it. Every time it does it it is changing into overdrive.It last about three seconds and it doesn't do it every time it goes into overdrive. There does not seem to be a pattern. No noise or vibration in other gears. Would appreciate any thoughts. Thanks.
Old 12-04-2011, 08:21 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,571 Likes on 1,049 Posts
It could be torque converter clutch shudder. A complete transmission fluid change often fixes this.
Here's how to do it yourself. Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
Old 12-04-2011, 08:22 AM
pappy19's Avatar
pappy19
pappy19 is offline
Tranny/torque conver going south or check your drive shaft and carrier bearing; U-joints. Hope that it is one of the latter, otherwise go to Sun Coast Diesel Transmissions - Home | Sun Coast Diesel Transmissions and look at a rebuild with a new TC.
Pap
Old 12-04-2011, 08:32 AM
1975StroppeBaja's Avatar
1975StroppeBaja
1975StroppeBaja is offline
I would start with a transmission flush. My wife's Taurus had these symptoms and a flush cured it for hers.
Good luck!
Old 12-04-2011, 06:58 PM
bicounty's Avatar
bicounty
bicounty is offline
Thanks. I will give it a try. In the link about flushing it gives type of fluids based on the transmission I have. I dont have a book so how do I determine which one I have. Thanks.
Old 12-04-2011, 07:49 PM
1975StroppeBaja
A 2004 will have the 4R100
Old 12-06-2011, 05:51 AM
bicounty's Avatar
bicounty
bicounty is offline
Thanks. I am getting supplys together to do a flush. I have read and heard a lot about friction modifer. Do I need to add this to the list of supplys. Thanks again for all the help.
Old 12-06-2011, 07:12 AM
Mark Kovalsky
Don't add friction modifier to the transmission!
Old 12-21-2011, 09:35 PM
Beatdown Z's Avatar
Beatdown Z
Beatdown Z is offline
How's the trans doing?
Old 12-22-2011, 02:33 AM
bicounty's Avatar
bicounty
bicounty is offline
Changed ATF and filter. Have driven about 100 miles. So far no sign of problem. Still keeping fingers crossed. Thanks everyone for help.
Tugly
30
07-02-2014 09:48 PM
CWSonnyCress
04-17-2006 01:42 PM
Chuky66
1997 - 2003 F150
28
02-12-2006 09:17 AM
04FX4
2004 - 2008 F150
07-23-2004 04:43 PM
dssmithiu
07-09-2000 10:00 PM
Quick Reply: 04 f350 with 5.4. auto transmission problems
