04 f350 with 5.4. auto transmission problems - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-03-2011, 10:57 PM
bicounty bicounty is offline
bicounty is starting off with a positive reputation.
I just bought truck. Only has 63000 miles. After driving for a few days I started feeling a vibration. At first I thought I was running over rough spots in pavement like the warning marks on the shoulder. It starting doing it more frequent so I began taking notice of when it was doing it. Every time it does it it is changing into overdrive.It last about three seconds and it doesn't do it every time it goes into overdrive. There does not seem to be a pattern. No noise or vibration in other gears. Would appreciate any thoughts. Thanks.
Old 12-04-2011, 09:21 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
It could be torque converter clutch shudder. A complete transmission fluid change often fixes this.
Here's how to do it yourself. Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
Old 12-04-2011, 09:22 AM
pappy19's Avatar
pappy19 pappy19 is offline
pappy19 has a very good reputation on FTE.pappy19 has a very good reputation on FTE.pappy19 has a very good reputation on FTE.
Tranny/torque conver going south or check your drive shaft and carrier bearing; U-joints. Hope that it is one of the latter, otherwise go to Sun Coast Diesel Transmissions - Home | Sun Coast Diesel Transmissions and look at a rebuild with a new TC.
Pap
Old 12-04-2011, 09:32 AM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
I would start with a transmission flush. My wife's Taurus had these symptoms and a flush cured it for hers.
Good luck!
Old 12-04-2011, 07:58 PM
Thanks. I will give it a try. In the link about flushing it gives type of fluids based on the transmission I have. I dont have a book so how do I determine which one I have. Thanks.
Old 12-04-2011, 08:49 PM
A 2004 will have the 4R100
Old 12-06-2011, 06:51 AM
Thanks. I am getting supplys together to do a flush. I have read and heard a lot about friction modifer. Do I need to add this to the list of supplys. Thanks again for all the help.
Old 12-06-2011, 08:12 AM
Don't add friction modifier to the transmission!
Old 12-21-2011, 10:35 PM
Beatdown Z Beatdown Z is offline
Beatdown Z is starting off with a positive reputation.
How's the trans doing?
Old 12-22-2011, 03:33 AM
Quote:
Changed ATF and filter. Have driven about 100 miles. So far no sign of problem. Still keeping fingers crossed. Thanks everyone for help.
Some seriously bad vibration Dude-Ford 1999 - 2003 7.3L Power Stroke Diesel 14 01-15-2017 01:25 PM
Vibration when starting out under load, Reason? Papa Charlie 1999 to 2016 Super Duty 9 07-01-2016 11:13 PM
390 Rough Idle pit_of_pity FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 17 03-24-2011 05:50 PM
Vibration in overdrive selbona 1987 - 1996 F150 & Larger F-Series Trucks 4 06-30-2010 09:09 PM
Intermittent vibration felt in steering wheel usmcBTC 1999 - 2003 7.3L Power Stroke Diesel 6 06-17-2009 08:34 PM
Tags
04, 2004, 350, 54, automatic, f250, f350, fluid, flushing, ford, problems, shooting, transmission, trouble, troubleshoot
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
