3g alternator swap - Page 2 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
3g alternator swap
Old 12-05-2012, 04:17 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
I might have used a different mount hole, there are 2 you can mount the bracket to.
Josh
Old 01-23-2014, 05:51 AM
mebe2k's Avatar
mebe2k mebe2k is offline
mebe2k is gaining momentum as a positive member of FTE.
reviving an old thread here.. but I finally got the g3 installed in my truck..(yes..I know I said I was going to do it 2 years ago)...I figured I would wait until the original 60A g2 died..and it finally did.. took that sucker a while.. but one of the brushes finally wore down to nothing..
Installing the G3 was pretty simple, once I ground enough of the 2.8L bracket off to clear the case..the wiring was the easiest part..puts out a nice 14.5V, with everything running, lights, A/C blower, radio, etc... Now I just have a bug to work out..
Bullitt390, did you have any problems with the belt squealing when the engine is first started? Mine will squeal for about 2 seconds, right when the engine starts..i've tried tightening the belt, and it helped a little, but it still squeals when the engine is started....after it squeals upon startup, it doesn't squeal any more..have had the engine upto 4,000 rpm and it is fine..I will try a new belt, since this one is probably glazed, I will also de-glaze the pulleys..thanks again for this thread..
Old 01-23-2014, 06:28 AM
Bullitt390's Avatar
No squealing at all. Definately try a new belt.
Josh
HOWTO - 3G Alternator Installation ctubutis '80-'86 HOWTO's 3 11-05-2016 11:09 PM
DIY Y-Pipe Repair Bullitt390 6.0L Power Stroke Diesel 27 11-16-2014 11:21 PM
DashBoss digital gauges for Ford 6.0 Bullitt390 6.0L Power Stroke Diesel 72 01-08-2014 10:26 AM
Shell Rotella T6 CJ4 0W40 is here!!! Bullitt390 6.0L Power Stroke Diesel 13 11-07-2013 01:25 PM
HO Alternator on a Budget 6G to 3G Bullitt390 6.0L Power Stroke Diesel 17 09-16-2012 08:24 PM
Tags
2003, 28, 3g, alternator, bracket, coverstion, escape, f150, ford, fusible, link, picture, ranger, rewinding, support, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
