Vacuum Wiper Motor
Vacuum Wiper Motor
I need to rebuild mine too. How about describing the various steps in detail for the rest of us? If it's anything like some of my endevors, then I'm sure you will make some, if not many, mistakes-wrong turns- or just general knucklehead moves. I always enjoy learning from other peoples' mistakes I'm being serious, Thanks, John
Vacuum Wiper Motor
I always thought that the grease was supposed to be there. It helps seal and lubricate the paddle. The reason most of these units don't work is because the grease has dried up. I just went through mine about 6 months ago. Cleaned every thing up and used liberal amounts of good quality bearing grease. Works great now.
I also used a vise grips to take it appart and replaced the screws with conventional phillip heads.
on
Vacuum Wiper Motor
Don,
You used bearing grease? I looked into a vacuum motor many years ago and I thought the grease in it was white lithium grease. I have two motors, but both are frozen. I guess dissassembling them would not make them any worse even if I can't get them to work. If I can't get either of them to work, guess I'll have to go electric.
Vacuum Wiper Motor
Lubricants in the 50's weren't what they are today, Nathan. I highly doubt that what you are seeing in engine gook that has been "sucked in". The vacuum FROM the engine pulls AGAINST the motor, not the other way around. If anything of the sort were to happen, it would be wiper motor grease being sucked back into the engine. My advice would be to clean it out good and relubricate it with an adequate amount of white lithium grease. That stuff is thin enough to allow the engine vacuum to easily move the paddle but it lasts about forever. I've never been inside one of these, but I've seen some diagrams and have a good idea of how they work. Is there a seal of some sort on the paddle? If so, I'd make sure that you get it replaced as well.
Vacuum Wiper Motor
Actually, I didn't use axle grease but chasis grease. Lithium might very well be the preferred stuff but at the time all I had on in the shop was my grease gun loaded up with muti-purpose moly grease.
Truth is, it probably dosn't matter much what you use. I would certainly avoid a grease that's to stiff or gets that way on a cold day.
If I remember correctly, the seal on the paddle is made of leather and not easily replaced. The bigger problem is saving the fragile paper gasget that keeps the whole thing air tight. However, a bit of silly cones generally saves the day.
Vacuum Wiper Motor
Originally posted by 51dueller
But why would they cover the whole paddle really thick?
