stuck valve cover!
Old 12-03-2011, 07:31 AM
peter_x's Avatar
peter_x
peter_x is offline
stuck valve cover!
Trying to remove the driver side valve cover. I got the four bolts off the top. Is there something else I can't see? I tried to remove one of the fuel lines with the spring lock tool but that seems stuck as well. It really doesn't need to be removed though. Can anyone tell me how to break the cover loose? I tried hammering with a block of wood but it's hard to get a good angle. Thanks.
It's a 1988 F-Superduty
Old 12-04-2011, 02:53 AM
jeremy2008's Avatar
jeremy2008
jeremy2008 is offline
take a screw drive or a flat scraper an put it between the valve cover an the head an work around it. Try not to dig in to the head tho.
Old 12-04-2011, 09:00 AM
cparks's Avatar
cparks
cparks is offline
There are 7 bolts total. Double check all 7 have been removed.
Old 12-04-2011, 09:19 AM
peter_x's Avatar
peter_x
peter_x is offline
Well I managed to get if off but there were definately only 4 bolts. I had to remove the upper intake to give me room to use a hammer and chisel. Even though it is off, I haven't removed it because of the fuel and EGR lines. I'm going to try to get the fuel lines off again right now. I don't know why I only have 4 bolts. Every source I found said 6 or 7.
Old 12-04-2011, 10:52 AM
peter_x's Avatar
peter_x
peter_x is offline
Finally done... the fuel lines needed some coaxing out even after the spring was pushed out of the way.
Old 12-05-2011, 01:14 AM
jeremy2008's Avatar
jeremy2008
u only have 4 bolts right on the top of the cover.
Old 12-05-2011, 07:19 AM
cparks's Avatar
cparks
cparks is offline
I was not thinking fuel injected.
factory carb 460 engines have 7 bolts per valve cover
factory EFI 460 engines have 4 bolts per valve cover
old bad daddy
Modular V10 (6.8l)
10-28-2012 08:43 PM
VQT
06-03-2012 04:41 PM
Nimrod.sixty9
12-29-2010 07:57 PM
Insley95
Modular V10 (6.8l)
05-22-2009 12:43 PM
Quick Reply: stuck valve cover!
