You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Has anyone seen a rear window rubber seal for the big wrap around window (1960 F250) that would be without the chrome? All of the seals I have found so far have the grove for the chrome.
__________________
Clayton Parks - Michigan
2012 Ford Raptor SuperCrew Supercharged 6.2
1957 Ford Ranchero 4x4 428 project
1960 Ford F250 4x4 521 stroker project
2000 Ford Excursion 4x4 V10
2013 Ford Escape
Cparks; according to my parts guide, there was just one seal for the wrap-around back window for 57-60 B7C-8142084B That would be channeled for the chrome trim as it was a custom cab. I don't know if the lack of trim in the seal would effect the function of the seal. A quick check shows green sales has a dozen of the seals. I have been known to give misinformation, so maybe numbers dummy (or someone else) will set us straight.
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
I have been looking on and off for a few months, and have yet to find one. Maybe like you guys are saying, it is because it does not exist. I was figuring that it did not come factory this way based one some research, but was hoping maybe an aftermarket company may be making one.
__________________
2013 Ford Escape
From the 1957/63 Ford Truck Parts Catalog (available on a CD from hipoparts.com):
1957/60 F100/1100:
B7C-8142084-A .. Back Glass Weatherstrip-Use without Wrap Around Glass / Reproduced
B7C-8142084-B .. Back Glass Weatherstrip-Use with Wrap Around Glass / Reproduced
That's it...there isn't another.
If you have a Custom Cab, but it does not have the mouldings...now...it did originally. A previous owner, at some point...likely replaced the back glass, as it had broken, omitted the mouldings.
With mouldings: The weatherstrip has a groove in it. It can be a PITA to install these mouldings, one possible reason why they were omitted.
Or...one or more of the mouldings (there are four) were damaged when the back glass was broken, possibly caused by something in the bed moving forward when a PO came to a stop.
B7C-8142404-B .. Back Glass Moulding-Lower Right / Obsolete
B7C-8142405-B .. Back Glass Moulding-Lower Left / Obsolete
B7C-8142430-B .. Back Glass Moulding-Upper Right / Obsolete
B7C-8142431-B .. Back Glass Moulding-Upper Left / Obsolete
AFAIK, not reproduced. No Ford Dealer or obsolete parts vendor has any.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
Thank you for the help. I actually damaged one of the pieces removing the window, and was thinking since I did not have the chrome around the windshield, I would just delete it on the back window too. But I will now see if I can have the piece repaired or find a replacement. Thanks again for the info.
__________________
2013 Ford Escape
