Old 11-03-2014, 08:45 PM
How-Tos on this Topic
Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
FINALLY!!! I got the Crown Vic front suspension!
Old 10-29-2014, 06:15 PM
fred shannon's Avatar
fred shannon
fred shannon is offline
Does anyone make a ujoint that fits the C V rack??
  #62
Old 02-09-2015, 08:45 AM
jenkinsj's Avatar
jenkinsj
jenkinsj is offline
351w into 58 f100
I have been following your build and I am just starting to put in a 351w into my 58 f100.
I am curious as to what you used for motor mounts and radiator before the crown vic swap. I have my engine sitting in the bay and it seems like there is not going to be much room left for the radiator. Were you able to use the belt driven fan?
Thanks.
Jack
  #63
Old 02-09-2015, 08:57 AM
elgemcdlf's Avatar
elgemcdlf
elgemcdlf is offline
It's called a Mustang V
  #64
Old 02-09-2015, 08:58 AM
elgemcdlf's Avatar
elgemcdlf
Thanks.
Jack
Jack,
You will have to fab your own motor mounts. You should have plenty of room for the engine. Set it as far back as you can.
  #65
Old 02-09-2015, 01:50 PM
jenkinsj's Avatar
jenkinsj
jenkinsj is offline
Is your truck a 67 or 68? Did you use the original radiator and support? i got the mounts made.
  #66
Old 02-10-2015, 06:33 AM
elgemcdlf's Avatar
elgemcdlf
Jack my truck is a '70 with a '67 grille. Everything is correct for the truck with exception of suspension and I put a 460 in it. Your truck is the same. There is a thread here by fast58. He did the CV in his '58. The only real difference between your truck and mine is your frame arches above the straight axle.
Your truck does have a shorter wheelbase. Back to fast58, he used all his original sheet metal up front. The only reason I could see for clearance issues would be the engine sitting too far forward.
I will look for his thread and post the link. I see you found his thread. No need to post a link. He does note he is tight to the radiator as well. Perhaps going to electric fans is a solution.
waltharper
01-04-2011 11:55 PM
brandon_stapleton
04-09-2010 09:46 PM
1970460
15
04-25-2009 01:24 AM
joelsutter
09-12-2004 07:29 AM
61 uni
07-22-2004 06:35 PM
Quick Reply: FINALLY!!! I got the Crown Vic front suspension!
