Headers for a inline 6 ??
Old 12-02-2011, 05:22 PM
ericford1984's Avatar
ericford1984
ericford1984 is offline
Can you get headers for a inline 6 I have an 84 f250 and can't get the intake/exhaust off to clean and re do the gaskets. Considering putting on headers if anyone knows of some. But how can I do that with the intake? Since they mount to the exhaust and it has the egr tube. Any info is great!
Old 12-02-2011, 06:01 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
There are a good number of headers made to fit these engines. There's even the 87-96 EFI models that used 2 separate 3-1 manifolds, like a V6 would have.
Most people do the manifold to header (or EFI manifolds) swap in conjunction with an intake swap, so the EGR tube isn't an issue.
The factory intake and exhaust manifolds are separate units, but they bolt together under the carb.
Old 12-02-2011, 06:08 PM
ericford1984
Well I have an 84 with a 1 barrel carb. Do you know where I could get the set up for the headers and keeping it separate from the I take? Thank you
Old 12-02-2011, 06:33 PM
fordman75's Avatar
fordman75
fordman75 is offline
Hedman 89300 Hedman Hedders Standard-Duty Uncoated Headers
Hedman Hedders 89300 - Hedman Street Hedders - Overview - SummitRacing.com
Old 12-03-2011, 01:11 PM
Harte3's Avatar
Harte3
Harte3 is offline
Save yourself some grief and use the EFI exhaust manifolds rather than the headers. On an otherwise stock or mildly modified 300 the headers are expensive bragging rights. The EFI manifolds are not prone to loosening, breaking, fitment problems, etc., and there is not enough performance difference between the two to make a difference.
Old 12-03-2011, 02:38 PM
ericford1984
And these efi manifolds are the same as stock 84 carb manifolds? Where can I find them?
Old 12-03-2011, 03:22 PM
fordman75's Avatar
fordman75
I disagree about the performance difference. The long tube headers will always perform better then the efi manifolds. But I do agree that on a stock or mild 300 the EFI ex. manifolds are a better choice. But they do have there issues too. I've seen plenty of cracked EFI ex. manifolds.
No they are not the same as the 84 manifold. The EFI exhaust manifolds are what came on 87 and newer EFI 300's. They are basically a pair of cast iron shorty headers. Being two separate manifolds with each having their own outlet they flow much better then the stock single outlet log style carb exhaust manifold. They will bolt up to the carb head.
Now you can either go to a salvage yard and pull a pair out of a 87-96 Ford truck or van with a 4.9L. Or you can search ebay and find a pair.
Old 12-03-2011, 03:25 PM
Rogue_Wulff
I thought I had pretty much covered what the EFI manifolds were........
Old 12-04-2011, 12:06 AM
72BigBlue's Avatar
72BigBlue
72BigBlue is offline
Another vote here for the EFI manifolds. Hard to beat their durability and sealing characteristics. I found a little casting flash that needed smoothing out, matched the ports to the gaskets. The ball and socket connections (manifold to head pipe) requires no gaskets, and is a good seal. Any headers I've had with the 3-bolt flange gasket has proved to need regular tightening and/or gasket replacement. Starter motor access may be a concern as well with headers. EFI manifolds I've seen also have threaded hole for EGR tube.
Old 12-04-2011, 12:17 AM
fordman75's Avatar
fordman75
The Hedman headers use ball and socket collectors not the old 3 bolt with gaskets.
Old 12-04-2011, 08:45 AM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
Old 12-04-2011, 10:15 AM
ericford1984
Ok so if I wanted to replace my stock intake exhaust bolted together manifold with the efi manifold. Would I still be able to use my 1 barrel carb? It's an 1984 f250. I just don't want to order install and have nothing work. Waste time and money!
Old 12-04-2011, 10:20 AM
dustybumpers
You can re use the stock set up. You will need toput a new starter in when you put the headers on, it is impossable to replace the starter with the headers in place.
you also have to relocate the brake line. I would go with the efi manifolds for your app, it would be pointless to put headers on a stock set up.
Old 12-04-2011, 12:26 PM
Harte3's Avatar
Harte3
Harte3 is offline
With headers or the EFI manifolds the feature of the stock manifold set-up for heating the intake will be removed. With a Clifford or Offy 4v manifolds this is no problem as water heat can be used. I'm not sure what can be done to heat the stock intake. Without the heat there might be driveability issues due to gas dropping out of suspension and puddling in the bottom of the intake...loss of atomization.
Old 12-04-2011, 12:31 PM
dustybumpers
You can still use the heat kit from Kevin, the bottom of the intake is the same
Quick Reply: Headers for a inline 6 ??
