Where is this oil leaking from (pics) 7.3 6-speed
My problem was here. It is on the drivers side just to the left and below the fuel filter and HPOP
https://www.ford-trucks.com/forums/1...-oil-leak.html
Ok, I think I've got it:
The nut is not loose, but the hose has a lot of play on the fitting.
I assume it's the oring, I can watch the oil seep reappear.
I've read Replacement O-rings for Ford Diesel Engines
I have a cheapo kit of o-rings that may get me by, what is the o-ring size and how do I replace, the hoses don't disconnect using the nut I gather.
Thanks, the pan seemed quite solid, I crawled under and checked that before I bought the truck. The oil pan was the first thing I was warned to check out by the dealership. The build up in the photos is the gooey undercoating that is stuck on almost everything on the truck, just like the front cross member by the pan. The pan is solid black anywhere I scraped off the goo. I think I might clean it all off and paint it up sometime to be safe anyways.
The funny thing was the fitting that leaked was the one at the front, not the one in back like I thought. The oil was running along the HPOP and coming out under the back line.
My valley was still dry a few days after the repair and no more drip coming down the back. I have spent a lot of time cleaning up all the oil off the block and trans the best I could so I can watch if it leaks again.
Squirrel13
02-19-2019 08:08 AM
JoeDaf
03-03-2018 10:46 AM
