Engine Block Heater - Ford Truck Enthusiasts Forums
Engine Block Heater
Old 12-02-2011, 03:50 PM
lowfly lowfly is offline
lowfly is starting off with a positive reputation.
Engine Block Heater
I have never had a vehicle that had a plug-in for a heater in the engine. My question is when should it be plugged in? It's a 2005 PSD with 60k on it and I only drive it about once a month during the winter. It rarely gets below 27-32 degrees in the coldest times here in Central Texas. Should I leave it plugged in all the time when not in use?.....only at night when it gets below X degrees? Any help or advice is appreciated. Thanks.
Old 12-02-2011, 04:09 PM
gunnarGSD gunnarGSD is offline
gunnarGSD is starting off with a positive reputation.
I don't even think about pluging in until about 5 degrees(f), or -15(c). Starts fine everytime. 27-32? forget about it.
Old 12-02-2011, 04:39 PM
EXbowtieguy's Avatar
EXbowtieguy EXbowtieguy is offline
EXbowtieguy is gaining momentum as a positive member of FTE.EXbowtieguy is gaining momentum as a positive member of FTE.
I plug mine in anything -30...... May not need it but my truck seems to love it ! (no growl)
Now if I could figure how to make it not frost the windshield I'd be straight !
Old 12-02-2011, 04:40 PM
BPofMD's Avatar
BPofMD BPofMD is online now
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Electric heater INSIDE the cab...... sure would be expensive tho.....
Old 12-02-2011, 05:18 PM
Quote:
Uh huh..... Is kinda nice to have almost instant heat/ defrogger
Old 12-02-2011, 06:40 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is online now
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
I plug mine in a lot also. It really likes warm starts, they all do.
Set your heater controls to full hot and on Defrost. Heat rises right up and out.
I used to plug my semi in all winter, and I never had ice on the windshield. Temps as low as -15*f, no ice.
Old 12-02-2011, 07:17 PM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
I would suggest using a timer and setting it to come on 3or4 hours before you need the the truck. You can select the temp you want to use it but freezing (32*f) might be a good place to start. It's not going to hurt to use it or not outside of those parameters. But why pay for the electric if your not using the truck. If I remember right it's 1500w. Imagine how much you could light your place up with 15 100w light bulbs running around the clock. There's no thermostat feature so if it's plugged in- it's on.
Be sure to get a timer rated for that much current, and the extension cord too.
Old 12-02-2011, 11:31 PM
Ian123's Avatar
Ian123 Ian123 is offline
Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.
If you only drive it once a month anyway, I would just plug it in a couple hours before each time you drive it.
Old 12-03-2011, 08:56 AM
Also .... I'd drive it more than once a month if possible.
Seems that that advice is as valuable as getting a scanguage.... These things don't like to sit, and like to have the PIZZ run out of them once in awhile.... That's what I tell my wife as she's got the white knuckle grip on her sissy bar , hard to here the over the whistle
Engine block heater time Jesse73iditurbo Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 02-16-2017 07:24 AM
my 2005 6.0 won't start when it gets below 40 degrees stringean1221 1999 to 2016 Super Duty 12 01-08-2017 10:21 PM
No Start Below 55 Degrees papatioman 6.0L Power Stroke Diesel 22 04-15-2016 01:37 AM
Heater Core Caleb H 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 87 02-13-2016 11:04 PM
Why is engine heater going bad? comsupany 1999 - 2003 7.3L Power Stroke Diesel 9 12-26-2015 12:24 PM
Tags
73, block, diesel, engine, engines, f150, ford, heater, monitor, oil, plug, police, sct, temp, tempature, tuner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
