2001 4.0 SOHC intake picture - Ford Truck Enthusiasts Forums
Old 12-02-2011, 10:58 AM
SEAL1 SEAL1 is offline
SEAL1 is starting off with a positive reputation.
Can anyone post a picture of the, top of the engine with the plastic intake manifold removed or the bottom of the one piece plastic intake manifold that shows the gasket surfaces for this years engine. This is different than the 97-2000 two piece manifold and I have been unable to find it anywhere.
Old 12-13-2011, 05:23 PM
Another PO174 code with a rough idle solved with new intake gaskets. Can't say as I have ever seen that much gunk and oil in an intake before.
Old 12-14-2011, 08:59 PM
Redneck1465 Redneck1465 is offline
Redneck1465 is starting off with a positive reputation.
Is this what your talking about?
If you need one let me know I have one off of a brand new motor never ran didn't need it. We could probably work out some sort of deal.
Old 12-15-2011, 06:18 AM
Thanks for the response. The reason I wanted a picture was that my manual only showed the two piece type but said mine was a one piece. I wanted to make sure that I had the right gasket set before I tore it apart. Once I tore it apart it turned out to be the two piece manifold after all.
Update dpfe burnt manifold jetfiremuck Aerostar 0 12-18-2016 12:28 AM
Intake manifold torque specs? ROBBINthaHOOD Modular V10 (6.8l) 3 11-15-2016 10:56 PM
unplugged egr lines, need help stevenjf88 1987 - 1996 F150 & Larger F-Series Trucks 2 06-05-2015 06:05 PM
2002 expy 5.4 lower intake manifold wtroger Expedition & Navigator 6 11-16-2014 05:00 PM
Replacing intake manifold on a 5.4 Superdave Modular V8 (4.6L, 5.4L) 6 03-03-2010 04:10 AM
Tags
2001, 40, 40sohc, explorer, ford, gasket, gaskets, intake, manifold, performance, piece, removal, replacement, single, sohc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
