06 Quigley Remote Oil Filter Lines - Ford Truck Enthusiasts Forums
Old 12-02-2011, 10:08 AM
mtnxtreme800 mtnxtreme800 is offline
mtnxtreme800 is starting off with a positive reputation.
Can anyone tell me which is the feed and which is the return line on an 06 E350 6.0stock remote oil filter housing?
Old 12-02-2011, 10:54 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
Do you mean the transmission filter? There is no remote engine oil filter.
Old 12-02-2011, 11:34 AM
Quote:
On the e-series vans the oil filters on the 6.o are located on the drivers side, ahead of the tranny filter, trying to figure which hard line is feed and return.
Old 12-02-2011, 12:39 PM
Really? Sounds like an easy mod for compound turbo setups, surprised nobody has done that yet.
Old 12-02-2011, 04:38 PM
This is true, I'm actually in the midst of doing a remote oil cooler and I'm going to tie into where these lines exit the oil cooler housing or maybe right into them if they are of the correct size, won't know till I dig a little deeper.
Old 12-02-2011, 07:32 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
quick way to find out. remove the filter housing and crank it over
Old 12-03-2011, 07:07 AM
Quote:
Good idea, but sounds messy, can I pull something so she won't fire, like pulling the coil wire on a gasser. I was hoping someone was hiding a diagram showing flow. There's gotta be something out there.
Old 12-03-2011, 07:28 AM
Jimbob8's Avatar
Jimbob8 Jimbob8 is offline
Jimbob8 is starting off with a positive reputation.
On page 34 of the 2004 6.0L Updated Coffee Table Book it shows E series oil
filter & identifies lines.
JIMBOB another redneck with an opinion
Old 12-03-2011, 09:56 AM
cheezit's Avatar
pull the grey relay from the fuse block. thats the ficm relay
Old 12-03-2011, 11:15 AM
Is 04 and 06 the same? Can you possibly post that, I do't have the manual.
Old 12-03-2011, 11:16 AM
The relays under the hood?
Old 12-03-2011, 11:24 AM
cheezit's Avatar
yes it is.
Old 12-03-2011, 02:42 PM
Jimbob8's Avatar
Quote:
http://www.ford-trucks.com/forums/88...nuals-pdf.html
Old 12-03-2011, 03:26 PM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03 SoCalSuperDuty03 is offline
SoCalSuperDuty03 is gaining momentum as a positive member of FTE.SoCalSuperDuty03 is gaining momentum as a positive member of FTE.
Quigley
mtnextreme it is kind of off topic, but if you get a chance post a pic of your Quigley. I am going to find me a nice one and am always looking for ideas on the look that I want.
Old 12-03-2011, 06:48 PM
Quote:
It's on the lift right now,so subscribe my thread on me doing a DIY remote oil cooler, I'm gonna post pics as i go along.
EGR delete + remote oil cooler = no coolant filter necessary? Norma stitz 6.0L Power Stroke Diesel 14 09-09-2016 09:40 PM
oil line to use to install remote oil filter system speakerfritz 1999 to 2016 Super Duty 1 12-12-2015 05:42 AM
oil line to use for remote oil filtration system speakerfritz 6.4L Power Stroke Diesel 0 12-11-2015 09:42 AM
remote oil filter factory or aftermarket? 93 mix 'n match 1997 - 2003 F150 7 03-29-2010 06:21 PM
remote oil filter ickeskartom Oil & Lubrication 4 06-02-2003 11:19 AM
Tags
06, 2004, 250, 60, 99, cooler, diesel, e350, f250, filter, ford, lines, oil, power, remote, stroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
