miss fire on 5,6,7,8 - Ford Truck Enthusiasts Forums
Old 12-01-2011, 08:49 PM
ford150hunter ford150hunter is offline
ford150hunter is starting off with a positive reputation.
my truck is miss firing on 5,6,7,8 they shop that told me that said it had more codes but wouldnt tell me. i replaced all plugs and coils at 90k. i have 150k on it now should they need replaced again???before they went out one at atime but this time they all went out at once. could it be something else that controls that side of the engine???? i cant drive it to a store to get the all the codes read cause it runs too rough.need help or i have to tow truck to ford
Old 12-03-2011, 07:29 AM
elrodalonzo elrodalonzo is offline
elrodalonzo is starting off with a positive reputation.
Do yourself a big favor and go buy a code reader. You can get a decent one for about 60 bucks at someplace like Sears. That's about 1/2 hr. labor at your local Ford Stealership. You will use it again after this, I guarantee it. Then you go online and research your codes, fix the problem(s), erase the codes and you're back truckin with a smile of satisfaction on your mug!
Old 12-03-2011, 08:51 AM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Welcome to FTE.
Did you pay for the code reading that the service people would not give you all of the results?
If you paid for the reading you should have received all of the codes.
Take your vehicle to a local parts store and have the codes read and printed out.
This is a free service at my local Advance Auto, O'reilly's and Auto Zone stores.
I would have Advance print out the results for later reference.
Get all of the codes and then check them against the list here Ford OBD-II Trouble Codes
My Superchips 1715 programmer reads codes so I use it for my vehicles.
Old 12-03-2011, 02:10 PM
He said he can't drive it cause it runs so bad.
Old 12-03-2011, 08:47 PM
codes that came up
i borrowed a code retriever and the codes were
1) P0022 camshaft postion acttuator A Bank 2 timing over -retard
2)P0171 Bank 1 system too lean
3)P0300 random/multiple cylinder misfire
4)P0305 cylinder 5 misfire
5)P0306 cyl 6 misfire
6)P0307 cyl 7 misfire
7)P0308 cyl 8 misfire
8)P0316 misfire detected 1st 1000 revs
9)P2195 O2 sensor stuck lean bank 1 sensor 1
10)P2198 O2 sensor stuck rich bank 2 sensor 1
anyone know if this is just all cause of the mis fire in 5 6 7 8? think if i just chang the coils it will work or should i change all 4 plugs too?
Old 12-03-2011, 10:08 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
It sounds like the cam actuator on the left side bank went out. 5, 6, 7 and 8 are the left side cylinders on Fords.
Old 12-03-2011, 10:34 PM
BoydGilley BoydGilley is offline
BoydGilley is starting off with a positive reputation.
Miss fire
You might want to check for coolant in cyl 5,6,7,8 i just had this problem with my 2000 mustang. try checkin all the obvious thing first.Because if you are getting just a little coolant will cause it to missfire.
Old 12-05-2011, 12:53 PM
fixed it
after many hour on the internet tring to find out what was wrong i decided to change the VCT(variable cam timing solenoid) but ford calls it EVT (enginevariable timing solenoid). took about a have hour to get it off and 40 min to drive to ford to make sure they had the right part i got it. truck runs good all codes are cleared and none popped back up after driving it. just want to say thanks for all the input you all gave me and this site rocks....Ford On!!!!!!
Old 12-05-2011, 05:34 PM
shorebird's Avatar
I think that I can speak for all here when I say Terrific!
We exist to help.
Forscan questions CincyPSD Aftermarket Products 3 08-16-2016 11:02 AM
Sudden misfire of cylinders 5678 on 4.6 RW1998 1997-2006 Expedition & Navigator 43 01-23-2016 05:57 PM
97 4.6 misfiring on all cylinders on the driver side abowman 1997-2006 Expedition & Navigator 28 05-11-2015 02:31 PM
Rough Idle/ No Power - Cant Accelerate - HELP!! mkzg Modular V8 (4.6L, 5.4L) 1 10-03-2013 07:03 AM
1979 302 firing / timing issues wesford Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 08-17-2013 09:00 AM
Tags
2004, 40, 5, 54, 6, cylinder, f150, fault, fire, firing, ford, miss, missfiringon, mustang, p0022, p0171, p0300, p0305, plug
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
