'97 f150 pcv valve buzzing loudly
The pcv valve buzzes loudly on my 5.4 engine and if I go at highway speeds for a while when I stop the engine stumbles a bit. It seems like there is too much vacuum. If I pinch the hose going from the valve to the manifold the buzzing stops. Any help would be appreciated.
Originally posted by Racerguy
Hi pbjames1 and welcome to FTE
Have you tried replacing the PCV valve? I cant think of anything else that would cause it.
Best thing is a new PVC Valve only cost a couple of bucks!!
If only all the parts were that cheap.
Good luck
PCV valves are plastic housings with carefully machined steel poppets inside. There is a very specific flow vs. vacuum requirement. If you have buzzing, your steel poppet is bouncing back and forth between the seats. I think you may have a PCV hose crack which is not permitting enough vacuum to reach the poppet. It raises a bit, then falls, then raises, then falls.
