460/Aod Is This Possible? - Ford Truck Enthusiasts Forums
Old 12-01-2011, 03:24 PM
JB78f150's Avatar
JB78f150 JB78f150 is offline
JB78f150 has a good reputation on FTE.JB78f150 has a good reputation on FTE.JB78f150 has a good reputation on FTE.
I have a 78 f150 4x4 with 351m/c6. I'm wanting to put in a 460. The question is that I'm thinking about putting an Aod trans in it. Is there anyway to do this or do I have to stick with the c6.
Old 12-01-2011, 07:50 PM
NW 150's Avatar
NW 150 NW 150 is offline
NW 150 is starting off with a positive reputation.
They had those two together in the 90's 250's/350's I know of at the least, so I don't see why not. Someone else might be able to tell you otherwise.
Old 12-01-2011, 08:59 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Apparently yes: Ford 429/460 to AOD
Old 12-01-2011, 10:09 PM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.
For what that adapter costs, you can buy a controller for an E4OD, which is a MUCH better transmission. It won't play nicely with the 205 thats in that F150 though.
Old 12-02-2011, 10:07 AM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is online now
LARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to behold
Quote:
In stock form, the AOD was never offered behind anything larger than a 5.0/302 from Ford. The only exception was the police cars that were outfitted in the early 1980s with a 351 H.O. with an AOD transmission.
Old 12-03-2011, 06:40 PM
NW 150's Avatar
Quote:
I must be thinkin of the wrong one then. Friend of mine's 97 f350 before he built the engine and swapped in a c6, has the 460, and had an automatic. It's not the aod?
Old 12-03-2011, 07:25 PM
HIO Silver's Avatar
Performance Automatic offers an AOD to 460 conversion kit but it ain't cheap....starts at $3,971:
Performance Automatic - AOD Ford Transmission
Performance Automatic - AOD Ford Street Smart System
Old 12-03-2011, 08:00 PM
LARIAT 85's Avatar
An AOD wasn't offered behind a 351, much less a 460, and certainly not an F350. The AOD was considered a light duty transmission. However, they can be beefed up to work behind the bigger engines.
The AOD was dropped after 1993. Your friend's F350 must have had a 4R70W, which is a revised, computer-controlled automatic overdrive transmission. The earlier AOD has no computer to run it and is completely mechanical, making it a popular swap on older vehicles.
Old 12-03-2011, 09:55 PM
NW 150's Avatar
Thank you for the correction, as I don't need to be giving out false information!
Old 12-04-2011, 06:22 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
351W/AOD: 1980/81 Lincoln Town Car / 1980/89 LTD/Crown Victoria/Mercury Grand Marquis & Police Cruisers.
Didn't look after 1989.
Old 12-04-2011, 09:25 AM
LARIAT 85's Avatar
Thank you for the correction, NumberDummy. I don't need to be giving out false information either!
Old 12-04-2011, 02:01 PM
74 F350 SCS's Avatar
74 F350 SCS 74 F350 SCS is offline
74 F350 SCS is gaining momentum as a positive member of FTE.74 F350 SCS is gaining momentum as a positive member of FTE.
I had a '90 F250 2WD SC w/460 and auto transmission. It came with factory overdrive with a switch on the dash to activate it, when desired, but I couldn't tell you they model or type of transmission but I'm sure Bill would know.
I too would like to have something like that in my '74 F350 w/460 but based upon my research, it would be very expensive and probably cost prohibitive.
Old 12-04-2011, 02:22 PM
LARIAT 85's Avatar
The AOD never had the switch on the dash to de-activate the overdrive gear; that would have been one of the newer computer-controlled automatic overdrive transmissions.
The overdrive on the AOD could only be de-activated by the gear selector on the column. The column on the AOD would have been set up like this: P R N OD D 1. The OD would be the overdrive gear of course, and the D would be the overdrive lockout position. The earliest models would have had P R N OD 3 1.
Old 12-04-2011, 04:07 PM
E4OD / The O/D switch could be on the dash, but it's also on the end of the shift lever (depends on apps), is notorious for snapping off. At least once a wwek, someone is b!tchin' about the little charmer.
Its: P R N O D 2 1 / Never seen a AOD (Ford: AOT) quadrant with OD.
O typed in red for emphasis purposes only.
Old 12-04-2011, 06:01 PM
LARIAT 85's Avatar
My 1985 F150 has P R N OD D 1 on it. The "OD" doesn't really look like that; it has the letter "D" with a circle around it. But there is not a "2" anywhere. Every AOD I have ever seen has this pattern except for the real early ones, and they have P R N OD 3 1 for the shift pattern.
1978 F-150 460, Can I swap the C6 for an AOD? SuperCruiser78 1973 - 1979 F-100 & Larger F-Series Trucks 6 01-27-2014 03:34 PM
Transmission Swap C6 TO AOD 78FordTruck78 1973 - 1979 F-100 & Larger F-Series Trucks 20 02-13-2008 12:10 PM
C6 to AOD Swap witdog2020 Clutch, Transmission, Differential, Axle & Transfer Case 5 01-09-2006 07:47 AM
C6 to AOD conversion info needed 02FX4Dude Clutch, Transmission, Differential, Axle & Transfer Case 11 11-02-2004 05:47 PM
AOD swap with C6 highp90town Clutch, Transmission, Differential, Axle & Transfer Case 8 09-06-2004 11:13 AM
Tags
2wd, 429, 460, 4x4, aod, aod460, auto, computer, cotrolled, ford, forum, good, od, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
