starter going bad?
starter going bad?
Hey guys I replaced my rpm sensor yesterday and went to start my truck and it just clicks. Is it the starter or the starter solenoid? Also has anyone repair one for a 7.3 idi? I have taken apart a starter and cleaned it and made it work but that was for a little Toyota corolla
Yes the batteries are good there brand new I bought them 4 months ago and I haven't really drivin the truck much because its my winter vehicle.I started it last Wednesday 11/23/11 and it started just fine and I let it run about ten minutes.I have had a couple incidents of it clicking before but it started after a couple tries and this time I tried for like five minutes and it just kept clicking
Jump the two big terminals on the fender mounted starter relay with a wrench or similar. If the starter then runs the relay may be bad. If starter does not run then check that all battery wire terminals are clean and tight and that the main battery ground wire is tight where it bolts to the engine.
Received 3,103 Likes
on
I had a friend once who left his taxi (Carbodies Fx4 Diesel) in gear on a hill and it rolled and started and went through a neighborhood brick wall and into the front of their house
I can remember a guy that worked at my grandads gas station working on car a 49 or 50 model, at least something in that timeline, anyway he was under it and jumped the starter. It started and ran over his legs, then through a cinder block fence, acrosss the street and used the sheriffs car sitting at the court house to stop it. It broad sided the sherriffs car, doing quite a bit of damage. He had no DL but they could not ticket him, because he wasn't driving and this was way before the days of mandatory insurance, so the sherriffs dept was just out the damage. They were sure trying to catch him driving after that though and he wound up with several no dl tickets. lol
I had issues with my starter this summer. Sometimes it would click a few times, just like a dead battery or bad connection would. After a few tries and some worry, it would start up. Then one hot day after a good drive and an errand, it did the same thing. When it finally started turning that day, it wasn't fast enough to start the engine. After a tow home and swapping in the starter from my spare engine I couldn't believe how much faster it spun over.
So if its still an issue after checking the connections, get a new starter.
Worked great for about 8 months, but then it failed inside the garage at Krown, and I had to crawl around on my back in anti-rust goo to fix it... not worth it. New starter.
The wire from the fender relay runs down to the starter solenoid. Check that it is properly connected to the solenoid. Check that the main battery wire is properly connected at the starter. If that is all good then use a wrench or similar to jump the two big terminals on the back of the starter solenoid (key off trans in neutral). If the starter then runs it may be that the starter solenoid is bad and you could just replace it. If starter does not run and you just get sparks then starter may be bad.
There is probably a short length od heavy gauge braided wire on the solenoid terminal opposite to the one with the main battery wire, check that the braided wire is not burnt/broken/corroded.
guitarnik
09-02-2008 08:04 AM
