FE overdrive
#31
#32
Here's my short-shaft TKO-500 mated to a 360FE.. no adapter plate required if you tell Bruce or Paul at Modern Driveline what you're doing.
EZ... even uses the mechanical linkage. If going from a T-18 or NP-435 on a long bed, get the coupling shaft from a C6-equipped FE/long bed and its length is spot-on. Lastly, the trans mount moves back one inch... just drill a coupla new holes. ..Five speeds. Glory.
#35
Do you know what model transmission is would be
#36
#37
#38
#40
#41
#42
Just because someone stuck a fork in it doesn't mean it's not a juice clutch.
#43
That's true. However I see no point on that bellhousing to mount an external slave cylinder.
#44
Any chance you could repost or send me the pictures of the short shaft TKO 500? I'm considering going the same route but I'm trying to gather as much info as possible.
Thanks
#45
I think you would have better luck if you sent Hio a PM or an email. You might have to get more than 5 posts under your belt first though.
