Wont shift from park, brake lights work with pumping - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 12-01-2011, 11:55 AM
Inkme Inkme is offline
Inkme is starting off with a positive reputation.
So Wife got stuck at QT today. Wont shift out of park. Thinking fuse, I went to rescue her cute *** and found the fuse to be fine.
Now I this is where i get confused...
NO brake lights initially
Pumped them fast about 5 times, got the lights and the shifter back
good till I put it back into park.
Now it repeatable. Pump hard about 5 times, then shift.
ANY ideas???? Fuse is good.
Old 12-01-2011, 10:55 PM
400 .040over 400 .040over is offline
400 .040over is starting off with a positive reputation.
test teh brake light switch
Old 12-02-2011, 02:09 PM
pgonza2723 pgonza2723 is offline
pgonza2723 is starting off with a positive reputation.
Brake light switch would be the most obvious culprit. If you have your wife stand behind the truck when it won't shift out of park...see if the brake lights are coming on or back up the garage door and do the check.
Old 12-15-2011, 10:22 AM
Been two weeks since replacing the brake light switch and so far haven't run into any more problems fyi
Old 12-15-2011, 11:02 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Quote:
Were you having the same problem as Inkme or did you change your name?
Old 12-15-2011, 11:03 AM
Same problem but updating my previous post to state my experience. Hopefully help someone down the road with the same issue.
Old 12-15-2011, 11:04 AM
berry1234's Avatar
Ahh. Nice. How much did the switch cost and how hard was it to replace?
Old 12-15-2011, 12:02 PM
Dealership didn't charge to install it...They said list was $78 ...but sold it for $40
Old 01-02-2012, 05:11 AM
cop on my back's Avatar
cop on my back cop on my back is offline
cop on my back is starting off with a positive reputation.
I just had to replace my switch as well, same problem. No tools needed to replace, just twist the switch and pull it out to remove the wire harness plug. The plug is the biggest PITA, might need a pair of plyers to squeeze the tab.
Old 12-12-2012, 05:08 PM
graypatrick093 graypatrick093 is offline
graypatrick093 is starting off with a positive reputation.
2007 Eddie Bauer Expedition with power pedals. Got the part from the Ford House. $35 plus tax. Brake light switch in and out in under 2 minutes. I used a 16 penny nail and pressed the tab down and it popped right out. Works like a champ now. Thanks for the info.
Old 12-18-2012, 05:51 AM
LA FAMILIA LA FAMILIA is offline
LA FAMILIA is starting off with a positive reputation.
BRAKE LIGHTS NOT WORKING & WONT SHIFT OUT OF PARK.
SO I HAVE A E450 THAT THE BRAKE LIGHTS ARE NOT WORKING & FUSE IS GOOD SO IM TOLD 2 REPLACE BRAKE SWITCH ON PEDDLE & STILL CAINT SHIFT OUT OF PARK IT HAS THIS INTEL LOCK SYSTEM THAT I WAS THINKING OF A WAY OF BYPASSING DOES ANYONE HAVE ANY IDEALS
Can't Shift from Park. #15 Fuse Blown IWPhoto Modular V8 (4.6L, 5.4L) 1 10-29-2016 07:47 AM
Baffled about 1999 ford f150 4.2 4x4 5 speed monsterjammer 1997 - 2003 F150 11 09-22-2016 05:35 PM
94 f150 wont shift out of park???? matt.likes 1987 - 1996 F150 & Larger F-Series Trucks 2 08-02-2014 09:57 AM
96 No Brake Lights, Will Not Shift Out Of Park 66BlackCat Aerostar 5 10-03-2010 04:38 PM
Truck Will not Shift out of Park mavfan2977 1997 - 2003 F150 17 05-25-2008 08:14 PM
Tags
1996, 2007, 78, brake, brakes, dont, expedition, ford, light, lights, park, pumped, ranger, shift, switch, truck, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
