2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
08 expy limited wiper on all the time
Old 12-16-2012, 05:45 PM
tbe2002's Avatar
tbe2002
tbe2002 is offline
Hey guys I need some help here. I having issues where my front wipers and sprayers come one a min after the truck starts up. This just started last week. Came home looked at the truck and noticed that the wipers were in the up position on the windshield. Went to look at it. Battery was dead. used my jumper box and started the truck and a min later the wipers and sprayers came on and wouldn't go off.
I decided id replace the battery with a new Motorcraft battery. That didn't fix the issue. If I pull the fuse for the "front wiper logic" inside the cab they will stop.
Today I decided to take a look around that fuse block inside and the wipers came on and wouldn't go off. The truck was off. No sprayer this time. I then had to find the wiper fuse under the hood and pull that to get it to stop.
If I disconned the multifunction switch the wipers do not turn off. Is this a BCM issue or could it just be a wiper motor issue?
Thanks all
Old 12-17-2012, 09:09 AM
tbe2002's Avatar
tbe2002
tbe2002 is offline
Issues got worse last night after the post. Took it to the dealer. Ended up with no turn signals in the front only. No turn signals on the mirrors. Blubs are good. Just a fas flash as if a bulb is out. No easy out on the seat and a brake light in the instrument cluster. Ill keep you all updated as to what they find. Hoping there are bcm codes to direct them somwhere.
Yeppie...... Not.
RUSTANG67
18
12-29-2020 05:25 PM
AbandonedBronco
1978 - 1996 Big Bronco
10-12-2013 06:03 PM
Icefan71
1997-2006 Expedition & Navigator
02-08-2013 01:58 PM
holiday187
1999 to 2016 Super Duty
07-30-2007 11:31 AM
F3504ME
05-14-2006 11:26 PM
Quick Reply: 08 expy limited wiper on all the time
