You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
What MPG is everyone getting with there 6.0's with what done to them?
That's a loaded question. A 2WD truck will get better mileage overall than a 4WD; a stock height truck will do better than a lifted one; and how fast you drive is another factor. With all that said, I'm running a 19.3 mpg average over 110 fill-ups covering 48k miles.
I'm one of the slower drivers out there...seldom run faster than 70 mph; slow roll up to/from stop signs/lights; don't beleive in "rolling coal" and always keep up with my PM's. I think in a couple of hours you'll discover this a "can of worms" type of topic.
__________________
FTE Arkansas chapter member
1972 Ranchero GT (351C CobraJet intake)
2001 Explorer XLT 2WD
2004 F250 6.0L 2WD CC "Pavement Princess"
2007 Monaco Starwood SL 31BHD
2012 Focus SEL (Wife's ride)
Appreciate the reply and yes this can turn into that type of topic. I hope it does not. I am just looking for a basic answer as in "2005 4x4 whatever programmer this size tire averaging 18-20mpg"
I doubt you'll see a 4WD truck get 20 mpg without keeping the speed below 60mph. There is too much drag in the front axle/transfer case. The type of tire & air pressure your running will also effect the efficiency of the truck. Running street radials at 60+ psi will do better than all terrain at 45-50 psi...that is what I'm doing Michelins street radials at 60psi.
__________________
my 06 4x4 mostly stock with stock sized tires and 4" straight exhaust i get about 11 city/ 15 highway. Towed my mud truck last week up to michigan and back, i got 12 mpg. Thats with nearly 10K behind me @ 70 mph!
__________________ Guzzy
1989 F250 Custom
351W with Crane 444232 Cam, 1.7RR in GT40 heads, summit shorties (waiting on Pacesetter LTs)
Isn't the fastest thing, but we will pull your house down
2005 crew cab, long box, 4x4, Stock tires (75psi -tires rated up to 85psi), 4" straight pipe, tonnue cover, egr delete, BullyDog GT set on performance, air raid air filter in stock box
daily driving in town 13-15 mpg
highway 18-20 mpg (70-80mph)
stock I got 16.5 highway and 13 city
__________________
05' F-250 PSD 6.0 FX4 Lariat- 4" turbo back w/ 6" tip - coolant filter - high amp alternator - 55 gal aux fuel tank hidden in the tool box w/ tank selector - Bully Dog with Pyro - Snow Perf Stage 3 water/meth - 240K and climbing - tty head bolts holding on for dear life
I am absolutely stock and average about 13 to 15 around town typically. My wife and I recently drove it on a 3300 mile trip (from San Diego area thru Oregon and Washington, east into Idaho, then south back to San Diego area), where I carefully calculated the milage every tank. Before we left I changed the oil (Shell Rotella T), had the transmission fluid changed, changed both fuel filters, and made sure the tires had 50 psi in the front and 55 psi in the rear (tires are stock size BF goodrich). We also ran Stanadyne in every tank. Gas milage (calculated) ran 18.5 mpg to 21.5 mpg, with the average for the whole trip at about 19.5. Also... I was not "easy" on the gas pedal, and in a few spots, I really wasn't easy on it!! By the way, and interesting to me, was the fact that the "gas milage meter" above the windshield consistently read about 0.5 mpg above actual (calculated).
2004 4x4 CC - All Stock - 275/75/16 AT - 16 mpg avg in Houston traffic.
Same truck---Same Milage---Different citys traffic....
Whats funny is I was getting roughly the same average before I upgraded to 285/75/16 Mud Terrains and added a tuner running a performance tune.
No more no less...... As if thats just what its meant to be
__________________
2004 F250 4X4 Lariat CC ,Marinco bumper outlet for block heater--Sinister Coolant Filter--High Idle Mod-- Arp's--Egr Delete--Edge Insight CTS w/EAS system also monitoring EGT,Fuel Pressure,Oil Pressure--Sct SF3 (waiting for Innovative tunes)-- a work in progress
Stock two wheel drive eight ft. bed. 13 to 15 city, 18 to 21 hiway, 14 to 17 mixed. Towing the 31' fifth wheel it gets 11 to 13 depending on hiway and speed. Average 11.6 to the Sierras and 13.2 on return trips. That is all on normal days with no high winds, rain etc. Sierra trips are a 260 plus mile trip each way with no fill ups. When towing I set the cruise at 60 mph where ever possible.
__________________
"05 F-250, 6.0, CC, LB, 3.73, 4 X 2, Lariat, with coolant filter and Bilstein shocks, Magnefine p.s. filter, Ford fuel press. spring upgrade and ScanGauge ll. S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
2007 FHLP H.D. Road King
2007 Thor Jazz 5er, 11k dry weight, 31'
173rd Abn. RVN.
2006 4x4 cc muffler and cat delete sct tuner set on performance 19-22mpg 60-65 mph
__________________
-2006 F-250 XLT 6.0L diesel, SCT tuner, scan gauge II, muffler and cat delete, 3.73 gears, 135,000 miles
-1998 Pont Grand Prix GT 237,000 miles
-1992 f150 302, 3.55 gears, 4in lift, headers, true dual exhaust, no cat no muffler, 33in tires- wish i wouldn't have sold it
In town, back & forth to work, 13 (at best) - but to qualify that, my trip work is only 3 miles (a tank lasts about 1 month)
We just traveled TX to NC & Back - on the way to NC we towed our 7k# TT and got 12, on the return not towing we got 17 the first 1/2 of the trip and 15 the 2nd 1/2 (30 mph head wind).
I also learned a valuable lesson... when towing, never let the tank get below 1/4 and when the low fuel light comes on... it's to f'ing late! Sat on the side of I10 for an hour waiting on roadside assistance
__________________
- The Urban Assault Vehicle -
2006 F250 Super Crew, 6.0 L PSD
2001 Prowler 31G, Equal-i-zer WD Hitch
