Which LED's to use for the map lights?
V-LEDS.COM | LED Dome, Map, License Plate, Reverse, DRL, Turn Signal, Brake Lights
map lights are 194
and if you have rear courtesy lights, they are festoon type 578 (3 of them)...
order the 5k for max brightness. 6K is just more shade of blue.
map lights are 194
Note that the Recon part number 264163 kit works only for the rear seat dome light in a Crew Cab without a Sunroof. The are not the correct bulbs for the front map lights. Recon mistakenly indicates these will work, but trust me they won't work in the front. You need the 194 Led bulb for the front map lights.
Appreciate this thread too, alot of small mods that we can do. Just installed the recon smoked lens and 3rd brake light today.
I used these and they work great. Very white.
4x 194 168 5-SMD White High Power LED Car Lights Bulb : Amazon.com : Automotive
While we are on the subject of lights and not to hijack but...
Does anyone else think it is strange the the back dome lights do not come on with the front dome lights in a crew cab?
Is there a setting that I have overlooked that will make them work together?
Pitts- here is the link to the video showing how to modify the rear Dome light cluster so all three lights come on when the dome light it on. He actually used two diodes, not resistors - my mistake.
http://www.youtube.com/watch?v=n0zRrVtsGkI
Last edited by Michael53; 08-28-2012 at 12:26 PM. Reason: Added Link to video on wiring rear Dome lights
Aussie 53
15
03-12-2008 08:33 AM
cobrar97
10-04-2007 11:01 AM
