What type coolant I can use in this 7.3L? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 12-01-2011, 02:51 AM
Milwaukee1979F150's Avatar
Milwaukee1979F150 Milwaukee1979F150 is offline
Milwaukee1979F150 is gaining momentum as a positive member of FTE.
Well after read couple threads here. I am little confused now.
Some say you can use supertech green coolant from walmart but some say NO NO because it will eat injector cup.
This truck is 00 with 220K miles. It had new water pump before I bought. Coolant is green. 7.3L powerstroke was made in July 98.
I bought one coolant bottle from NAPA it turn out it was wrong. Coolant is red. I read that I not supposed put red coolant on mine because they will cause gel and eat injector cups. Is that true? $17 a 1 gal
Old 12-01-2011, 03:13 AM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
Lets try and clear up your confusion then brother.
I dunno what kind of coolant that is, but if it's a coolant that's considered a conventional "green" coolant (like vehicle manufacturers have been filling from the factory for years), then the Supertech won't hurt anything, just make sure you use a Supplemental Coolant Additive with it and check it with test strips.
For what it's worth, in all my research and reading, I've never come across any information stating a coolant will eat an injector cup.
You have a model year 2000 truck, but it was made in July 1998? Huh? Something doesn't jibe.
It won't cause gel, but if you have an Early '99 rig, you shouldn't use an Extended Life Coolant.
Here's some information I've posted previously:
Quote:
Originally Posted by Stewart_H View Post
The following information from Gooch pertains to why ELC's are not recommended for use in early '99 7.3L PSD's.
Mostly it's the injector cups. International, who made the engine, found some compatibility issues with the older injector cup material, sensors, front cover, seals, gaskets, o-rings, and probably some other stuff when using coolants that contained organic acid technology (OAT). Coolants like ELC's (usually Red) and G-05 (usually Gold) will have these OAT's. Conventional coolants (usually Green) will not.
So International revised those components on all 2/2/99-up build engines (SN 940614-up), and began recommending and factory filling with HD ELC coolants mid-year 2000. Never looked back.
You could use HD ELC's in the older engines, but you run the risk of having to replace the cups and maybe some other stuff. I always try to recommend conventional coolant meeting ASTM D4985 with SCA or a pre-charged conventional coolant meeting ASTM D6210 for those. But it's your call, and some owners use the ELC in their older engine successfully. For the 2/2/99-up builds I would highly recommend upgrading to HD ELC.
BTW, if you need to check the build date of your engine, you can find it on the valve-cover tag (driver's side), or stamped on a machined surface on the underside of the engine, behind the oil filter and just ahead of the bell-housing cover. You may need to wire brush/clean it to read it.
Stewart
One last thing, don't go by the color. Just because a coolant is red doesn't mean it's always going to be a Heavy Duty OAT ELC. Know what the coolant is, and you'll know what applications it's used for.
Stewart
Old 12-01-2011, 03:55 AM
Thank for info. That was great. Going give you rep.
I think I misunderstand on engine date. Going to look at valve cover tomorrow to make sure I got date correct. It had AD injectors. It not early 99.
I had 6 of those Walmart.com: Super Tech 50/50 Antifreeze/Coolant Pre-Mix: Automotive
Do I should avoid ethylene or propylene glycol?
Old 12-01-2011, 03:57 AM
LSO1123 LSO1123 is offline
LSO1123 is gaining momentum as a positive member of FTE.
So do you have a '00 truck that has had an early '99 engine dropped in it for some reason? If that's the case Fleetcharge will work for you. You can get it at Tractor Supply, Advance Auto Parts and other places I'm sure. If you have a 99.5-2003 engine, from what I've read International recommends red ELC coolant such as CAT ELC, Peak Final Charge, and some others. Either way, none of it's real cheap!
Old 12-01-2011, 12:36 PM
rufushusky's Avatar
rufushusky rufushusky is offline
rufushusky has a great reputation on FTE.rufushusky has a great reputation on FTE.rufushusky has a great reputation on FTE.rufushusky has a great reputation on FTE.rufushusky has a great reputation on FTE.
You want to run an ethylene glycol coolant in your truck, not propylene. You also don't want to "change" coolant with 50/50. You want 4 gallons of concentrate and a bunch of distilled water.
More info on coolant than you will EVER want to know...
http://www.ford-trucks.com/forums/96...ml#post8935201
Old 12-01-2011, 07:28 PM
Tim J Tim J is offline
Tim J is starting off with a positive reputation.
Bummer....so I'm destroying my e99 by running Rotella ELC? what would some e99 owners recommend?
Old 12-01-2011, 07:30 PM
can you replace injector cups?
Old 12-01-2011, 08:14 PM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
On E99's conventional green coolant and adding SCA's(Supplemental Coolant Additives). Yes the Cups can be changed
Riffraff Diesel: Motorcraft 7.3L Injector Cup Kit
Old 12-02-2011, 05:23 PM
Sorry for respond late.
It say July 22 1999 That mean it early 1999.5? I believed 1999 or older had AB injector.
Ok I am having trouble contact ford dealer's part shop on phone to find price on SCA.
Old 12-02-2011, 05:30 PM
Stewart_H's Avatar
You're fine to run an OAT Extended Life Coolant.
Stewart
Old 12-15-2011, 01:39 AM
Ok I was going to do oil cooler.
I bought 5 gallons of Fleetcharge coolants. But after check google search I think I made mistake. edit I found I could get cheaper. It Mobil one EC-1 ELC coolant.
It ok to use Fleet Charge but it doesn't have rate of Cat EC1.
This is what I had. Fleet Charge Specifications Sheet
I read it had Low silicate formula But everybody say NO silicate it will clogged all cooling system.
I want double check with you people.
Old 12-15-2011, 05:03 AM
Stewart_H's Avatar
If I read that correctly, all Fleet Charge is, is a coolant pre-charged with SCA's.
Think of it this way, the Supertech coolant you wanted to buy from Walmart is a coolant you would have to add SCA's to, if you used it in your truck.
The Fleet Charge already has the SCA's in the coolant, so you don't have to add any to it after you fill your truck up.
Who is "everybody?"
What kind of coolant do you want to run in your truck? A conventional "green" that needs a SCA's? A hybrid OAT like the Ford "gold" or the Zerex G-05? Or a heavy duty OAT Extended Life Coolant?
Stewart
Old 12-15-2011, 06:25 PM
I return these coolants to NAPA it was cost $80.
Friend get me Mobil one EC-1 ELC coolant it only $40 for 4 gallons of antifreeze.
Everybody I was talk about from Powerstrokenation. They say silicate could end abrasive and destory water pump and clogged oil cooler.
Old 12-15-2011, 08:37 PM
Stewart_H's Avatar
That's seems pretty cheap for the concentrate. Make sure it's not the 50/50 mix.
Coolant with SCA additives do cause water pump failures over a long period of time. Silicate drop-out is one reason ELC is a much better coolant, because ELC doesn't use SCA's to protect against cavitation.
Clogged oil cooler problems are pretty much a 6.0L PSD problem, but not 7.3's too often.
Double check that stuff your friend sourced for you. Make sure it's not a 50/50 mix.
Stewart
Old 12-15-2011, 08:44 PM
Stewart
It come from Big semi mechanic shop. They get bulks of those. I will check. If it 50/50 it ok to use?
Dan
Coolant bigreentruck 1999 - 2003 7.3L Power Stroke Diesel 6 12-04-2016 09:16 PM
OBS 7.3 Coolant 0500757Arf 1987 - 1996 F150 & Larger F-Series Trucks 10 11-14-2016 12:50 AM
How bad did I mess this up? bigalsmith102 1994.5 - 1997 7.3L Power Stroke Diesel 35 12-22-2015 09:37 PM
pink coolant in 95 psd arkredneck 1994.5 - 1997 7.3L Power Stroke Diesel 8 01-05-2014 10:31 PM
What correct coolant for 5.4L in F250? Milwaukee1979F150 1999 to 2016 Super Duty 2 07-06-2012 09:27 AM
Tags
03, 2000, 2002, 73, 73l, 95, antifreeze, collant, color, coolant, f150, f350, ford, super, tech, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
