How does 4x4 system on F350s work?
I just picked up my 2002 F350 XLT 4x4 and realized I have no idea how the 4x4 system works. (I have barely driven the truck!)
In otherwords, does the rear differential lock when you engage 4H?
For those trucks with rear limited slip, is it a viscous LSD or mechanical?
How about the front diff, does it lock when you engage 4H? Is it limited slip?
Is this 4x4 system meant to be used on wet pavement? Or only loose surfaces or snow?
Thanks,
Lex
Thanks,
Lex
No, your truck won't have a locker in the rear unless someone installed an aftermarket unit. And if that's the case, the 4x4 system won't have anything to do with it locking & unlocking.
The stock LS a typical clutch based LS unit that performs average at best.
No, pretty much the same answer as that of your first question. You won't have a locker or LS up front unless someone installed an aftermarket unit. Again, the 4x4 system won't have anything to do with it locking/unlocking.
I would not use it on wet pavement unless absolutely necessary. It wouldn't be as bad as dry pavement but it would still put the driveline in a bind around turns. That being said, a few weeks back I actually had to engage my 4x4 on wet pavement because the hill was so steep and there were wet leaves all over the road. But it was a straight run and only about 20 feet at 2mph.
Hope this helps!
Hope this helps!
Jason,
Thanks for responding. This is what I expected.
If the system binds, this means the driveshafts much be "locked together" at the transfer case or the differentials are locked when in 4H.
I used to drive a Ford Ranger and this truck would lock its rear diff in 4H. It was a worthless 4WD system except for in snow or dirt....
Bummer....
pdrhodes1
05-05-2005 12:33 PM
