Oil temp. sensor location? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-30-2011, 08:53 PM
cutlass's Avatar
cutlass cutlass is offline
cutlass has a good reputation on FTE.cutlass has a good reputation on FTE.cutlass has a good reputation on FTE.
I'm in the process of adding an oil temp. gauge and I'm wanting to know where everyone is mounting the sensor who has one. I'm assuming somewhere on the HPOP reservoir. I appreciate any input anyone has to offer.
Thanks,
Drake
Old 11-30-2011, 09:24 PM
woodnthings's Avatar
woodnthings woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
The factory oil temp sender is in the HPOP reservoir. You can mount it there, or you can mount it in the oil filter housing if those plugs are available.
There is a plug normally where I have this hose mounted. That is an oil pressure port.
Old 11-30-2011, 09:37 PM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Here's a good thread on the subject. http://www.ford-trucks.com/forums/10...-location.html
Old 11-30-2011, 09:43 PM
cutlass's Avatar
Is the temp. reading going to be the same if I placed the sensor in the HPOP reservoir vs. the oil filter housing? Maybe I should ask if one location better than the other for any reason?
Old 11-30-2011, 09:56 PM
They will be a little different. It really doesn't matter that much as long as you compare similar temperatures. The factory chose the HPOP reservoir, I use their sensor along with my Aeroforce Scan Gauge to read the temps. I try to keep my oil temp under 200*. The oil temp will be pretty consistent since the coolant is what is used to cool it.
I also take my oil pressure off of the HPOP reservoir. This allows me to see if the HPOP is ever starving for oil. My pressures may be lower than off of the block, but it doesn't matter since I know it could be lower there.
Old 11-30-2011, 10:51 PM
cutlass's Avatar
Thanks for your input everyone! I decided to use the oil filter base location for my sensor.
Oil/Trans Temp "combo" gauge?? finallyo3gt 1994.5 - 1997 7.3L Power Stroke Diesel 18 07-16-2016 09:47 PM
oil pressure and coolant temp sensor mounting 86scotty Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 10 05-19-2014 10:51 AM
95' E250 Trans Temp. Sensor Stored Ford 1968-2013 Full Size Vans 4 12-24-2010 10:20 AM
Where to install a Autometer trans temp sensor in a E4OD? shuttlevalve 1987 - 1996 F150 & Larger F-Series Trucks 4 06-16-2010 07:35 PM
Oil Temp Sensor? brownie83 1999 - 2003 7.3L Power Stroke Diesel 15 04-06-2010 12:32 PM
Tags
1980, 2002, 4x4, 73, 73l, 96, engine, f250, f350, gauge, location, oil, se, sensor, temp, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
