Brake Light Switch - Ford Truck Enthusiasts Forums
Brake Light Switch
Old 11-30-2011, 07:19 PM
1972RedNeck's Avatar
1972RedNeck 1972RedNeck is offline
1972RedNeck has a good reputation on FTE.1972RedNeck has a good reputation on FTE.
Brake Light Switch
On my '66 F250 4X4, I have to push quite hard (locks the tires up on dirt roads) to make the brake lights come on. I assume the brake light switch is going bad. Where can I get a NOS one?
Thanks
Old 11-30-2011, 07:23 PM
63' f100 63' f100 is offline
63' f100 is starting off with a positive reputation.
I don't know if its the same one as mine, but you can get a brake light switch at any auto store.
Old 11-30-2011, 07:30 PM
Broomfieldbum's Avatar
Broomfieldbum Broomfieldbum is offline
Broomfieldbum is gaining momentum as a positive member of FTE.
I bought mine at Advance Auto. It cost about $5.00.
Old 11-30-2011, 07:37 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The pressure activated (by your foot) brake lamp switch is notorious for becoming gummed up with dirty brake fluid.
C1AZ-13480-A (replaced 91A-13480) .. Brake Lamp Switch (Motorcraft SW-24) / Available from Ford and a gazillion autoparts stores.
Applications: Myriad 1939/66 FoMoCo vehicles / Same as Studebaker #666858 = 1941/66 Studebaker, 1951/54 Packard, 1955/56 Packard Clipper w/o Torsion Bar suspension, 1957/58 Packabaker.
Old 11-30-2011, 07:39 PM
bunchoftrucks's Avatar
bunchoftrucks bunchoftrucks is offline
bunchoftrucks is starting off with a positive reputation.
If that doen't do the trick check your blinker switch because that where my brake light issue finally was resolved. All the power that comes from the brake switch goes through the blinker switch then to the brake lights.
Old 11-30-2011, 07:45 PM
Quote:
My brake lights work. You just have to mash the pedal to the floor.
Old 11-30-2011, 07:46 PM
Quote:
I'd bet they aren't made in the U.S. of A.
Old 11-30-2011, 08:23 PM
You might check the blinker fluid.
Old 11-30-2011, 10:37 PM
Isn't that stuff hard to come by for these old trucks? Maybe NumberDummy can get us a part number.
Old 12-01-2011, 01:29 AM
Quote:
Sorry, there is no part number, nor is there one for the muffler bearings or the Johnson rod.
Old 12-01-2011, 11:18 AM
Buzz44's Avatar
Buzz44 Buzz44 is offline
Buzz44 has a good reputation on FTE.Buzz44 has a good reputation on FTE.
Johnson???????? Rod??????????
Old 12-01-2011, 03:58 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Here is a lower PSI activation brake switch used by hot rodders and custom car builders.
Brake Light Switch for Inverted Flare - Speedway Motors, America's Oldest Speed Shop
A Johnson Rod is used to provide timing for seam engine valves, Unlike Kaniflin Pins
Garbz
Old 12-01-2011, 05:11 PM
The Masked Rider The Masked Rider is offline
The Masked Rider is gaining momentum as a positive member of FTE.
"muffler bearings or the Johnson rod",,, I better go back and read the rest of this thread. Ya can sure tell winter is coming. :O)
Old 12-01-2011, 08:17 PM
Buzz44's Avatar
Garbz
So it is heat seeking then......... Thanks for clearing that up for me. I do have the right one.
Old 12-01-2011, 08:52 PM
Quote:
1959/61, I pumped gas on weekends at a Texaco station. Whenever a customer asked what was wrong with their vehicle, the mechanic would say: "It's probably the Johnson rod."
No brake light or hazards Keith Free 1978 - 1996 Big Bronco 4 09-04-2016 01:52 PM
1988 brake light problem wrd0225 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 05-04-2016 04:49 PM
no brake lights mike 1973 - 1979 F-100 & Larger F-Series Trucks 16 01-07-2016 10:56 PM
no brake lights continued russell christy 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-26-2013 07:27 AM
No Brake Lights Larzon 1987 - 1996 F150 & Larger F-Series Trucks 3 11-18-2012 07:56 PM
Tags
1964, 2008, 2wd, brake, break, control, f100, f150, ford, light, lights, navigator, recalls, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
