5r55 Transmission failure prevention - Ford Truck Enthusiasts Forums
Old 11-30-2011, 04:01 AM
old farmer old farmer is offline
old farmer is starting off with a positive reputation.
After reading that it is fine particles that the filter can't catch coming from the clutches that causes servo bore and other wear, is there another way to rid it of those particles without requent fluid changes?
How about fine filtration? Is there a way it could be plumbed into the system to catch it? I am thinking of the bypass type filters available for engines.
Could it be plumbed into one of the cooler lines or would the oil overheat due to to little flow through the cooler?
Ideas welcome, thanks.
Old 11-30-2011, 05:52 AM
stuart1 stuart1 is offline
stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.
An inline filter can be installed.
Old 11-30-2011, 07:20 AM
ptf18 ptf18 is offline
ptf18 is starting off with a positive reputation.
stuart1 Can you give us some suggestions on a filter system? What is your thoughts on fluid changes, etc?
Old 11-30-2011, 08:06 AM
Part Detail
There are many out there, this is just one. ^. Up there.
Fluid changes are vital in todays, transmissions.
With computer controls even a smidgen of contamination can wreak havoc.
Pan and convertor fluids should be changed, along with filters, regularly.
If filters become clogged it is an indication of junk from clutch or band material.
A transmission overhaul MUST have a cooler line and cooler flush.
In many cases replacement of the radiator cooler is mandatory.
Amsoil bypass filter kit F6Guy 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 05-03-2010 04:09 PM
Bearing Wear Question Knotwild Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 08-10-2008 11:51 PM
Magnesol/Engine Wear Knotwild Bio-diesel, Propane & Alternative Diesel Engine Fuels 0 08-10-2008 11:27 PM
Filter Mag ? ? ? ? crenshawjm Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 04-07-2007 10:12 PM
Air Filters as they relate to oil, etc. BrianA Oil & Lubrication 78 01-22-2003 07:07 PM
Tags
2004, 2005, 5r55, 5r55s, air, bore, explorer, failed, ford, problems, replacement, servo, testing, tranmission, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
