Truck's going under the knife
Convert to GM hydro boost used on one ton 3500's as the diesel will have low vacuum to run a power booster. Much more compact and should fit in the stock location with an aluminum adapter for the three bolt GM unit to the four bolt firewall. It will have the same master cyl bolt pattern as a ford master and runs off the power steering pump.
Garbz
Garbz
I have a Suburban with the 6.2 and hydroboost, it's ok but it leaks. I also don't like that one system effects the other, if you're on the brakes and turn the wheel, there is a noticeable difference in brake assistance and steering effort.
I'm not too worried about the frame cracking, I converted this truck to power steering four years ago and only put 7500 miles on it so far. The frame looks nice and crack-free around the box.
Had it running today. I had to pull the fan off the 7.3 as it interfered with the upper radiator hose, but I managed to drop it and damaged the radiator. I didn't find the damage until I started pouring in the coolant, but I was able to recover all of it and pull the radiator for repair. I had to move the truck so I started and moved it out of the garage.
It's wild just how much power this thing has now, rev the engine a little and the whole truck rocks all over the place. It moved a bit with the 360 before, but nothing like it does now. The clutch engages a little lower than I'd like, and is really an on-off type thing, but it works and moves under it's own power and I should be able to drive it home tomorrow.
John
Something has to go very wrong very soon- This whole thing is just dropping together. Even the speedometer cable end fits right in the hole on the ZF.
I'm having to get a little creative with the throttle pedal and clutch master cylinder, but nothing too major. There are nice big open flat spots to mount this stuff in useable locations. I was worried I'd have to use an aftermarket master cylinder and mount it upside down under the dash or something, but the stock on will work fine.
I have a bet with a co-worker that I will drive this to work on Monday the 19th. So far, I'm on track to drive it home on Saturday.
I didn't like the position of the new hydraulic system's clutch release either,
Ford_Six! :/ But now it's only a memory of what it was like the first week or
two driving it after that, I hadn't noticed it at all. :)
('91 Bronco E4od to ZF swap)
I didn't know the old camera had a "flower" setting until after I took this
fuzzyass picture... ;)
The reason the pushrod is gold is because I made it from a brake pushrod...
...check out that crank pin after only 188k of "company truck" use. LOL :)
BTW, the firewall on that same truck is like-new stiffness-wise, so that part
does work. :)
Here's the brake pushrod's new-round-end...
Alvin in AZ
I'm putting a ZF in behind a 351W, both of which I took out of an 89F-250.
I snagged the support plate off of the firewall of the donor truck, hopefully I
can line everything up with that. I also took the pedal assembly out of that
truck to use in mine. Do you have pics of where you mounted everything on
the firewall?
the firewall?
does work. :)
Alvin in AZ
great project i want to go diesel in my crew but need to finish other projects first. can you get some pics of the clutch cylinder mounting and the motor mounts? i'd like to see how you mounted everything upi'm doing a zf5 swap in my 71 crew with a 460 i wish i waited alittle longer to redo the 460 and go with a diesel instead
#28
Well, I drove it home just a few minutes ago. It runs great but is LOUD in the cab. I'll have to add some sound insulation in there.
I'll get pics tomorrow after work.
As far as the mounts, I don't think I'll post pics of those. I'm not thrilled with how they turned out. I've seen worse, and these'll last for a while, but I want something different. I'm going to build a new pan and pickup so I can drop the engine down about 2" and back about an inch. Then I'm going to build a subframe to bolt onto the crossmember incorporating the perches.
#29
How the truck sits now:
I need to do some bodywork now that the truck is reliable.
Master cylinder mounting:
The giant Banks air cleaner didn't fit past the cowl, so for now I put an open element cleaner. The inlet on the 7.3 is the same as a standard 4BBL carb, so it fit right on. When I drop the engine down it'll fit so I'll just run this till then.
Fancy chrome tip:
Banks power:
Transmission crossmember:
I used sch.80 pipe I had for the crossmember, and welded the mount section of the 80s crossmember onto it. I'll try and get some better pictures another time, when I can get some light under there.
Fancy chrome tip:
Banks power:
