HelP Please Stuck Lifter - Ford Truck Enthusiasts Forums
Old 11-30-2011, 12:22 AM
Bundy4825 Bundy4825 is offline
Bundy4825 is starting off with a positive reputation.
Exclamation HelP Please Stuck Lifter
Hi guys i think i have a stuck lifter on my 1990 F150 4x4 351W i though i was doing the right thin and when i changed the oil ther other day i ran a bottle of engine cleaner threw befor i dropped the oil now my motor sounds great when it is sitting iddle in the shed but once its under load it sounds like there like a truck with the exhuast brake on (very loud and pooping noise coming from the end of the exhaust pipe) my mate has said they it sounds like a stuck liffter has anyone got any advise on how to change thease out
thanks
Old 11-30-2011, 11:16 AM
White Max's Avatar
White Max White Max is offline
White Max has a good reputation on FTE.White Max has a good reputation on FTE.
Quote:
Originally Posted by Bundy4825 View Post
... my mate has said they it sounds like a stuck liffter has anyone got any advise on how to change thease out...
Remove the intake manifold, remove the rocker arm of the lifter you want to replace, remove the pushrod, and replace the lifter.
Old 11-30-2011, 02:34 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Based on what you stated it sounds more like a stuck exhaust valve, one stuck part or all the way open, more then say a stuck lifter. Not to say a lifter couldn't be holding one open, just its no where near as likely a condition to happen.
Old 12-01-2011, 02:35 AM
Thanks i will try have a look and see if all the rockers and valves are moving the same thanks to everyone for your help i am a first time f truck owner and i am way out of my depth but im determined to work all the issues out my self
i will let you no how i go
thanks again
Collapsed lifter - 1977 302 - Flat tappet bhenders 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-04-2016 08:12 PM
1990 5.0 Bronco Transmission Knock Ryan1994Wright 1978 - 1996 Big Bronco 3 08-04-2015 05:31 AM
Need Advice for Stuck Lifter Kenny1968 1957 - 1960 F100 & Larger F-Series Trucks 6 08-22-2012 08:21 PM
valvetrain tick zaaac 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 5 01-31-2010 03:55 PM
What would a stuck lifter do? 96fourbanger 3.8 & 4.2L V6 2 07-07-2009 04:39 PM
Tags
1996, 2001, 42, 96, diesel, f0, f150, f350, ford, lifter, lifters, stuck, taurus, truck, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
