rearend ratios
rearend ratios
I'd probably look for a 3.50 with your combo and planned use. With the 4spd tranny you'll run about 2500 rpm at 65mph. Low gear in the tranny is probably adequate for takeoff with the trailer - especially if you can start out in second gear running empty.
I run a similar combo in my 86 150 so the above is from experience. Only variations would be our first gear ratios and tire size. I'm running 235 75 15 LT's.
