460 timing boost
Old 11-29-2011, 01:48 PM
94BigRed's Avatar
94BigRed
94BigRed is offline
460 timing boost
Well I finally got the problems worked out on my 94 460 engine swap. In celebration I was going to move up the timing a few degrees to try and push a little more out of the old horse. Is this a worth-while endeavor? Where should I move it to? Its a 460 bored .030 and has an rv cam and headers, stock intake with no horns. Also no pcv valve or smog pump. Any suggestions? Thanks for the help.
Old 11-29-2011, 02:04 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
With the factory setting being 10 degrees some have had great results bumping it up to 12 to 16 degrees.. It is dependent on the particular engine and set up, I would try about 12 to start with and if all goes well go to 14 or so and see if it does ok there (as in no pinging)
The increase does help with power and some say it helps with mileage..
Old 11-29-2011, 04:16 PM
94BigRed's Avatar
94BigRed
94BigRed is offline
Will I notice the ping at a still idle or revving it or will it be driving under load?
Old 11-29-2011, 04:27 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
the ping comes under load. full throttle, low rpm while in gear is the best way to check for it (if you have a manual). if it pings just back it off a hair. you can keep pushin it until it pings if you do it carefully, in small increments, testing between each adjustment.
if you have no pcv valve, did you add a breather?
Old 11-29-2011, 04:28 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I could only get 12* out of mine
Old 11-29-2011, 04:30 PM
Slip ford man's Avatar
Slip ford man
Slip ford man is offline
I use this method with its time saving ease, and good results...ignore the carb talk, and don't forget the spout.
Vacuum Engine Timing | MILEPOSTS Garage (Tech Tips)
Old 11-29-2011, 04:36 PM
94BigRed's Avatar
94BigRed
94BigRed is offline
No, I just capped it off with a plate and plugged the header with a plumbing plug.
And slip ford, should i disconnect the spout or leave it on?
Old 11-29-2011, 04:39 PM
Slip ford man
Not good...very corrosive gases, and pressure as well
Old 11-29-2011, 04:44 PM
danr1's Avatar
danr1
danr1 is offline
I'm not sure but thinking/hoping hes talking about the EGR and not the PCV here?
94BigRed's Avatar
94BigRed
94BigRed is offline
I was mistaken, its not the pcv valve. Its the one that allows exhaust gasses into the intake to be recirculated. I thought that was the pcv valve, but its not. No the pcv is still there. Sorry about that. Yeah, Dan, EGR. Thanks.
Old 11-29-2011, 04:49 PM
Slip ford man
Disconnect while setting, reconnect when your done.
Old 11-29-2011, 05:00 PM
94BigRed's Avatar
94BigRed
94BigRed is offline
Ok cool. Thanks everyone.
Old 11-29-2011, 05:04 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
You should never hear any pinging at idle or revving it. Ping, if any, would occur under load. That is why you have to experiment with what your combination will work with.
E30tdf
09-30-2006 05:54 PM
Big O Dave
11-26-2005 08:40 PM
RubberDuck
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
06-20-2005 12:54 PM
460linc
03-03-2004 10:31 AM
Quick Reply: 460 timing boost
